I’ve noticed that the sync process on macOS takes much longer than on mobile.
Please note that all clients are in the same network. In the first test nothing is actually to sync. Everything is up-to-date.
When I click on Synchronize on the desktop app (macOS) it takes about 4 seconds until I get the Completed message.
On mobile (Android and iOS) it takes one second.
For the 2nd test I don’t have any absolute numbers, but when syncing changes 5-10 notes, one can see the counter go up on macOS rather slowly. On mobile the counter and the sync operations is done in a fraction of the time.
iirc the perf on desktop was much better at one point.
I believe I found the reason: The desktop app uses HTTP/1.1, while the mobile apps use HTTP/2.0.
I don’t know. That was my point. I believe that either an electron update or some other change must have switched from h2 to http/1.1.
You implemented multiple connections for faster sync. This has a much higher impact on h2 than on http/1.1. I actually don’t even know, if there is an impact on http/1.1.
Ah, ok, I understand. However, this also means that CLI and desktop are using http/1.1 which is way slower in establishing connections. H2 can also help with the multiple connections Joplin can use for syncing. We should try to find an h2 option. I was looking into the following project, which looks promising:
Might be worth a try. But it’s a big change I think as we need to make sure all sync target types still work, and also need to check file upload which works a bit differently.
If there’s a benchmark that shows that this method is faster for Joplin (not in the general case), then maybe it’s worth investing time in this, but otherwise maybe not.
The only benchmark I can imagine is changing 50 items and check the log for the timing.
But the best benchmark would be to test this on Linux, since performance there is apparently really bad (according to several topics). Unfortunately I don’t have a Linux machine with a DE.
@laurent@tessus If you would like I can help since I am running Linux. If you want to perform the changes to HTTP/2.0 then I can run some sync tests by syncing different numbers of items.
I can attest to the fact that Linux is excruciatingly slow. There are times when there is only 1 note change and it can take upwards of a minute to perform a sync. For reference, my sync target is Dropbox.
I'm seeing the same difference between Android and desktop Linux.
With my small collection of 30-ish notes across maybe five notebooks, the desktop client takes 3-5x as long to "synchronize" when there's no changed content (basically check the server for changes). Doing the same syncs after adding a new note in either client doesn't noticeably change the time it takes.
Edit: I should specify that the server is Nextcloud; not sure if this makes a difference.
