Sync problem on windows work computer with onedrive
Hello
I am trying to sync joplin with my onedrivel from my work computer, but i get this error:
Last error: Error: Could not execute request after multiple attempts: GET ://graph.microsoft.com/v1.0/drive/root:/Apps/Joplin/info.json:/content
On the website it says the following:
{"error":{"code":"InvalidAuthenticationToken","message":"Access token is empty.","innerError":{"date":"2021-12-08T11:53:56","request-id":"09afdbe9-e4ab-4fc9-8bef-d0ce6e52c7ce","client-request-id":"09afdbe9-e4ab-4fc9-8bef-d0ce6e52c7ce"}}}
I am using version: 2.5.12
I am able to do it from my private computer but not from my work computer, anybody that knows what to do?
Is it OneDrive for business? So far as I know it isn't supported, only personal OneDrive syncing currently works.
One potential solution may be to reset the profile as posted here
Please make sure you have a backup before fiddling with the profile.
Similar (unsolved) thread with this error:
It is not Onedrive for business
I will try to reset the profile when i get time.
And to the similar error, i dont get that error in log i get:
2021-12-08 14:33:32: "DecryptionWorker: cannot start because no master key is currently loaded."
2021-12-08 14:37:14: "Trying to reload note that has been deleted:", "null"
OneDrive for Business is supported btw :wink:
