Sync on Filesystem not working anymore
Joplin 3.6.15 (prod, win32)
Device: win32, 13th Gen Intel(R) Core(TM) i7-1355U
Client ID: 6923bee5cc6749ce8bd927d554fbb726
Synchronisatieversie: 3
Profiel versie: 49
Ondersteunde Sleutelhanger: Nee
Alternatieve instance ID: -
Sync target: Bestandssysteem
Editor: Markdown
Revisie: c615726
Freehand Drawing: 4.3.0
File system
I have 2 PC's (both Windows 11), 1 SMB fileserver
PC 1 synchronizes ok
PC 2 does not, sync starts and finishes in a blink of an eye
Both are set to FileSystem, both have exaclty the same url (filepath, \\pc\share\directory)
Both can add, delete and change files in the target directory (outside Joplin)
I use the portable version of Joplin
I don't know what to check next, nor can I find logfiles
Thanks for your help in advance
Regards,
Herman
Expand the sync status and share the details shown there after syncing. Or ideally send over the full log file
In the profile\log.txt I found some interesting lines
2026-07-03 06:58:11: Synchronizer: Sync target remote info: {"version":3,"e2ee":{"value":false,"updatedTime":0},"activeMasterKeyId":{"value":"","updatedTime":0},"masterKeys":,"ppk":{"value":null,"updatedTime":0},"appMinVersion":"3.0.0","revisionServiceEnabled":{"value":true,"updatedTime":0},"revisionServiceTtlDays":{"value":90,"updatedTime":0}}
2026-07-03 06:58:11: Synchronizer: Sync target is already setup - checking it...
2026-07-03 06:58:11: Synchronizer: Sync target local info: {"version":3,"e2ee":{"value":false,"updatedTime":0},"activeMasterKeyId":{"value":"","updatedTime":0},"masterKeys":,"ppk":{"value":null,"updatedTime":0},"appMinVersion":"3.0.0","revisionServiceEnabled":{"value":true,"updatedTime":0},"revisionServiceTtlDays":{"value":90,"updatedTime":0}}
2026-07-03 06:58:11: Synchronizer: TaskQueue.stop: syncDownload: waiting for tasks to complete: 0
2026-07-03 06:58:11: Synchronizer: TaskQueue.stop: syncDownload: Done, waited for 0
2026-07-03 06:58:11: Synchronizer: [error] Error: Error: Error: Unknown system error -214689381: Unknown system error -214689381, scandir '\MBP2026\LData\RE\Joplin'. Path: \MBP2026\LData\RE\Joplin
Code: Unknown system error -214689381
at FileApiDriverLocal.fsErrorToJsError_ (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/file-api-driver-local.ts:26:23)
at FileApiDriverLocal.delta (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/file-api-driver-local.ts:82:15)
at tryAndRepeat (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/file-api.ts:111:19)
at Synchronizer.apiCall (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/Synchronizer.ts:372:19)
at Synchronizer.start (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/Synchronizer.ts:888:40)
at timeoutCallback (file:///C:/Users/Herman/AppData/Local/Temp/3FOimUDmuCXaQECyVTomQ8q3DOP/resources/lib/registry.ts:212:21)
2026-07-03 06:58:11: Synchronizer: Sync: finished: Synchronisation finished [1783054690852]
2026-07-03 06:58:11: Synchronizer: Operations completed:
2026-07-03 06:58:11: Synchronizer: Total folders: 0
2026-07-03 06:58:11: Synchronizer: Total notes: 0
2026-07-03 06:58:11: Synchronizer: Total resources: 0
2026-07-03 06:58:11: Synchronizer: [warn] There was some errors:
2026-07-03 06:58:11: Synchronizer: [warn] Error: Error: Error: Unknown system error -214689381: Unknown system error -214689381, scandir '\MBP2026\LData\RE\Joplin'. Path: \MBP2026\LData\RE\Joplin
Can I upload the entire file somewhere?
I found the file %appdata%\Joplin\Session Sorage\Log which contained
2026/07/02-15:13:47.538 df48 Reusing MANIFEST C:\Users\Herman\AppData\Roaming\Joplin\Session Storage/MANIFEST-000001
2026/07/02-15:13:47.538 df48 Recovering log #3
2026/07/02-15:13:47.538 df48 Reusing old log C:\Users\Herman\AppData\Roaming\Joplin\Session Storage/000003.log
The 000003.log file is binary and looking into it all I can recognize is "Version.1"
The Synchronisation Status shows
Advanced tools
Not downloaded: 0
Downloading: 0
Downloaded and decrypted: 0
Downloaded and encrypted: 0
Created locally: 0
Error: 0
Sync status (synced items / total items)
Note: 0/0
Folder: 0/0
Resource: 0/0
Tag: 0/0
NoteTag: 0/0
Revision: 0/0
Total: 0/0
Conflicted: 0
To delete: 0
I think the error you posted is the only relevant thing you will get out of the log.
That likely seems like something permission related, but not within the network drive itself, but Joplin being unable to access the network drive.
Check the firewall rules set for Joplin app, or maybe try installing Joplin and see if it's an issue only with the portable app.
I solved it without installing. Just by placing the data on another server.
Thanks for helping me.
Regards,
Herman
I encountered same filesystem sync issue on Linux with no errors in sync status and I found that sync fails when "Welcome!" notebook is deleted.
Also, "Directory to synchronize with" needs to be checked for errors. For example, a space character before /target/folder (" /target/folder/") makes Joplin to synchronize to /home/user//target/folder/
Best regards,
Wolf
