Sync issues
Joplin 2.14.19 (prod, win32)
ID client : 7f975809e7af470eb48f9d93dd1b9273
Version de Synchro : 3
Version du profil : 46
Trousseau supporté : Oui
Révision : 971c4e5
Backup: 1.4.0
Conflict Resolution: 1.2.3
Nextcloud
Hello to the forum,
Thank you for this great app; I have been using Joplin for many years now without any issues, until now...
I cannot manage to sync the notes from my desktop on my nextcloud instance.
But sync with my Android telephone works fine.
I attach my last log file.
Thank you for any help.
Log file
20240314 log.txt (12.2 KB)
Try this: go to the Joplin folder on your server, find the locks dir and delete it.
While doing so, be very careful to not open any of the .md files in the Nextcloud web UI (doing so can corrupt them).
Thank you for your quick replies.
I now have the following message on the sidebar
In case it may help...
Ultimately, I understood that the problems were coming from my NextCloud instance. After fixing these problems, the synchronization works perfectly. Thanks to the forum, especially @roman_r_m and @personalizedrefriger for their help
