Nextcloud
Error. Please check that URL, username, password, etc. are correct and that the sync target is accessible. The reported error was:
PROPFIND : Username or password was incorrect, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured (Exception Sabre\DAV\Exception\NotAuthenticated) (401): <?xml version="1.0" encoding="utf-8"?> <d:error xmlns:d="DAV:" xmlns:s="sabre/dav"> <s:exception>Sabre\DAV\Exception\NotAuthenticated</s:exception> <s:message>Username or password was incorrect, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured</s:message> </d:error> (Code 401)
