Hi there,
OS: Linux
Joplan version: 2.3.5
for some test purposes, I temporary removed the Synchronization settings and put them back, 100% identical, but now I get an error:
Error. Please check that URL, username, password, etc. are correct and that the sync target is accessible. The reported error was:
PROPFIND : (Exception OCA\DAV\Connector\Sabre\Exception\PasswordLoginForbidden) (401): <?xml version="1.0" encoding="utf-8"?> <d:error xmlns:d="DAV:" xmlns:s="sabre/dav" xmlns:o="http://owncloud.org/ns"> <s:exception>OCA\DAV\Connector\Sabre\Exception\PasswordLoginForbidden</s:exception> <s:message/> <o:hint xmlns:o="o:">password login forbidden</o:hint> </d:error> (Code 401)
This is really weird, it was working properly. My Nextcloud WebDAV URL looked, nevertheless, unusual when I compared it to what I can find NetxCloud docs & Joplin FAQ, but it works on my Andoid app with the same settings:
https://xxx.xxxxx.xxx/remote.php/dav/files/yyyyy/Joplin
where yyyyy is my NextCloud username
What could have messed up my Sync and how to get it back to work?
Thanks in advance,
58
