I’ve would love a bit of more highlight when we use the single quotes (xxx) , as now it only converts the text into monospace type. I was thinking in something ala slack (see first line at 2:25 the text in pink uses single quotes and is much more readable:
Colour doesn’t matter, choose whatever you want, the slack image is just an example of a good way of highlight this kind of text. What I mean is that currently is difficult to distinguish the one that is inside () that the normal one (as monospace font type is quite similar to the standard)
