Search By Letter
Mac 10.12.6
Joplin 1.7.11 Prod Darwin
Is there anyway to search through all the notebook by letter? For instance I have a sentence "Call automotive at 10am"
Currently if I type "auto" in the search it doesn't return and search results back. I have to type "automotive" for it to return a search result.
Also is there a way to have the word highlighted on the page when you click on a search result? Currently it just takes me to the page but doesn't highlight the word I was searching for. Thanks for the help!
According to the search specs on joplinapps.org you have to use auto*
Use a wildcard at the end auto*
the words are highlighted, or am i misunderstanding something?
Are you using the search box? Instead, try the Go to Anything under Go. That will get you what you want.
Personally, I never use the search box anymore.
