Scroll note body with keyboard in viewer
when I’m in layout mode ‘viewer’, open a note and focus the body with Ctrl+Shift+b I’m not able to scroll to the bottom by using arrow key or page up/down.
However, after cycling through layouts by using Ctrl+l all of a sudden scrolling with keyboard works.
It would be great if this would work without having to cycle through the layouts…
Any thoughts on this?
I think it makes sense and it should be a small change, so I’ve created a Good First Issue for it: https://github.com/laurent22/joplin/issues/2810
Now in v1.1.4 one isn't able to scroll note body with keyboard in viewer without mouse even with this workaround.
Is there any chance this gets fixed?
Are there any news?
Sadly a mouseless workflow isn't possible with Joplin at the moment.
