when moving the text cursor between a text paragraph written on Arabic (which is RTL) and a new line that is empty (which is LTR by default) using the keyboard right and left arrows it functions wrong
imagine being in the end of a paragraph in Arabic (which is in the left side), when you press left it goes on the new line which is correct (like pressing right arrow in the end of an English paragraph)
but that line if you continue pressing left returns to the previous paragraph which is the issue, imagine spamming the right arrow in LTR-only note, it will continue going down and down over time, but in this mix of LTR and RTL it will get stuck between two lines
so i see having a default direction for the entire note would make sense
