Reverse Insert setting on a Logitech K850 keyboard
Joplin 3.4.12 (prod, win32)
Device: win32, Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Client ID: 403ae46121d7481da04bd2d4055cf7ed
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
Backup: 1.4.3
Freehand Drawing: 3.1.0
Note Tabs: 1.4.0
On my K850 keyboard the insert key stuck in Overwrite mode inside Joplin and so when I try to insert text into existing text, the existing text is overwritten. Outside Joplin, for example as I write this topic, the keyboard is in Insert mode. I closed Joplin and restarted it --the keyboard is still in Overwrite mode.
Help! How do I reset the keyboard to Insert mode inside Joplin?
k2aqOfWubslsC[1] (44.6 KB)
Thank you for the issue report!
Was Joplin closed with File > Quit? If not, does closing Joplin with File > Quit, then re-opening it, help?
Context: Depending on the "Show tray icon" setting, Joplin may continue running in the background when closed.
