Android
Dropbox
Similar to previous /resources-are-not-syncing/29258 I suppose.
How to reproduce:
- Install Joplin for MacOS and import 14 notebooks in Evernote markdown format.
- Sync Joplin for MacOS to Dropbox and complete synchronization. Check that Dropbox copy is complete.
- Install Joplin for Android (Android v10, Kernel 4.9.118-24343300 ) and sync Android app to Dropbox (resources sync is default, "Always")
- When sync is complete, open any note containing an image, and find a "download" icon instead.
- Click the "download" icon and nothing happens.
- Read through the forums and the GitHub forums for similar problems and find that changing the resources sync to Manual or Auto and back may help.
- Change resources sync to Manual and try downloading an image manually. This time the icon background turns briefly blue when touched, but still no image download.
- Restart Android, change resources sync to Auto and resync Joplin all over again.
Message: Created local items: 9 Fetched items: 538/1000. Completed: 06/04/2024 13:03 (987s).
- Again try a few different notes with images, note that all fail to download when opening.
- Change resources sync to Manual and resync Joplin all over again. Note that Dropbox copy has not changed at all.
Message: Created local items: 1302. Fetched items: 1840/1840. Completed: 06/04/2024 13:23 (375s)
Now the images download when touched.
Questions:
- Why doesn't the first, second or third sync complete on its own?
- When a download image icon is shown, why does touching it not ALWAYS attempt to download the resource?
- If it's attempting and failing to download the resource, why no information about the failure?
system
Closed
2
