The version you are using.
- on iOS: 10.0.53
- on the Mac: 1.0.245
The operating system you are using.
- iOS 14.0
- macOS 10.15.6
It seems that there is a different behaviour in rendering tables on the mobile version than in the desktop version.
I searched the forums a bit and found a similar issue guiding me that the "rendering" is responsible for this issue. But that topic was closed a long time ago, see here for more infos:
The thing I am witnessing is that tables will not be rendered correctly on the mobile version while being fine on the desktop.
This seems to happen only if you not use a title row.
Note to show the behaviour:
- on mobile in normal view, not code view:
- on desktop in both views:
Just want to let you know of this.
I could get by by with adding " ||||| " above each table, wich doesn't affect the tables on the desktop version but adds an empty line on the mobile version
