Remove Tags from UI
Is there a way to remove the tag section from the main app. I don't use them it is distracting it being there.
You can tweak your CSS to hide it, the linked post shows the CSS you would need to do it.
If you need to know how to change the CSS then there is a rather good guide on the process:
Hello and welcome, a bit simpler suggestion:
You can hide the list of tags by clicking on "Tags".
