Regarding Link parsing
There are 2 problems
  1. The link aren’t parsed in list and sometimes even in lines without list
  2. The link if parsed doesn’t respect the indentation and goes straight to the front
There is no list here , but still link isn’t parsed
New thing that i noticed was where there’s gap the system parses it correctly but then messes up with link
@teynav welcome to the forum
For a start you could try stripping out all the leading tab spaces you are using. Starting with a tab causes Joplin to render anything afterwards as code and so, being told it’s code, it ignores any markdown.
Thanks a lot!!!
