Hi
Just wanted to hear your thoughts on adding a quick add feature like Evernote.
It seems possible to do with Electron. I’m willing to try and add it myself, but wanted to check first if this is something you would like as a feature.
Thanks
Hi
Thanks
That would be a useful feature, and if you can create a pull request for it, it would be accepted.
If you need some help getting the app to build or some other info on how to create notes, feel free to ask here.
