Proposal to harden the failsafe safety feature (OneDrive data loss issues)
In the past 3-4 months there have been a number of issues raised on the support forum where Joplin users who use OneDrive sync have claimed that their notes 'suddenly disappeared'. While it is not possible to determine if all cases were caused by the same issue, there is evidence through user feedback from @BeefStorm on this thread Restore Deleted Backups - #18 by BeefStorm that this issue can occur without any user interaction, via a re-authentication of OneDrive happening in the background, which may sometimes cause the sync target (special) folder on OneDrive to change and somehow bypass the failsafe mechanism when that occurs.
I have a proposal for how the failsafe could be hardened to be more protective from data loss on all sync targets, and optionally a possible way to allow the user to recover from the OneDrive 'special' folder suddenly changing when the authentication is refreshed:
During the delta step of the synchronization code, make it check whether the sync target (remote) contains an info.json file, following each invocation of the delta api which fetches the list of remote items, and also when synchronization is started (just before info.json is created). If it does not, then trigger a failsafe error specifying that the sync target is empty or damaged. To avoid hitting this error when doing the initial sync on a device, bypass this error if the local database contains no items in the sync_items table matching the current sync target (then when it starts syncing it will create the info.json so that subsequent syncs should work without issue).
If the sync target is OneDrive, also destroy the existing authentication when hitting that specific failsafe error, to force the user to log into OneDrive again when they next press the sync button, in a hope that it will re-authenticate with the original 'special' folder.
