macOS
Joplin 3.1.6 (prod, darwin)
Client ID: 8e74f3b26f2644539505e1d7ce930bb8
Revision: a746c02
ABC Sheet Music Plugin: 1.0.5
Backup: 1.4.2
Combine notes: 1.2.2
Conflict Resolution: 1.2.3
Csv Import: 1.0.1
Delete unlinked resources: 1.0.0
Draw.io: 2.2.0
Favorites: 1.3.2
Hotfolder: 1.2.0
Markdown Prettier: 0.1.0
Note overview: 1.7.1
Omnivore Sync: 0.2.0
Outline: 1.5.13
Quick Links: 1.3.2
Slash Commands: Datetime & More: 1.3.2
Suitcase: 0.3.3
Joplin Cloud
While I know the 3.1+ versions are pre-release, I figured I'd bring this to someone's attention.
On my desktop version on my Mac, I have two problems. Firstly, startup time is severely slowed (yes, I know its often slow, but it's unusually slow compared with earlier versions.) Further, there seem to be problems with several plugins. They work in 3.0.15, but nothing later.
  • Slash commands 1.3.2 does not work
  • Outline 1.5.13 appears, but does not link to the various headings
  • Markdown Prettier: 0.1.0 does not format the pages.
There may be others, but these are the main ones. And I realise that in the scheme of things, these are minor complaints.
The log shows a few errors. I've listed below the significant errors (the ones in red).
This error seems to be related to slashcommands
models/Setting: Could not save settings Error: Error: SQLITE_CONSTRAINT: UNIQUE constraint failed: settings.key: INSERT INTO `settings` (`key`, `value`) VALUES (?, ?): plugin-com.hieuthi.joplin.slash-commands.slash_definitions,[ ["datetime", "now", [ "yyyy-mm-dd HH:MM", "yyyy-mm-dd\"T\"HH:MM:ss" ] ], ["datetime", "date", [ "dd/mm/yyyy", "yyyy-mm-dd" ] ], ["datetime", "time", [ "HH:MM", "HH:MM:ss" ] ], ["datetime", "jdate", [ "yyyy年mm月dd日(ddd)"], { "dayNames": ["日", "月", "火", "水", "木", "金", "土", "日曜日", "月曜日", "火曜日", "水曜日", "木曜日", "金曜日", "土曜日"], "monthNames": ["一月", "二月", "三月", "四月", "五月", "六月", "七月", "八月", "九月", "十月", "十一月", "十二月", "一月", "二月", "三月", "四月", "五月", "六月", "七月", "八月", "九月", "十月", "十一月", "十二月"]}], ["string", "greet", [ "Hello", "你好", "Bonjour", "Hallo", "नमस्ते", "こんにちは", "안녕하세요", "Hola", "Xin chào" ] ], ["string", "task", [ "- [ ] " ] ], ["string", "todotxt", [ "```todotxt sort:default\n\n```" ] ], ["datetime", "todoa", [ "\"(A)\" yyyy-mm-dd " ] ], ["datetime", "todob", [ "\"(B)\" yyyy-mm-dd " ] ], ["datetime", "todoc", [ "\"(C)\" yyyy-mm-dd " ] ], ["datetime", "todod", [ "\"(D)\" yyyy-mm-dd " ] ], ["datetime", "todoe", [ "\"(E)\" yyyy-mm-dd " ] ], ["calendar", "calendar", [null,"en-US","ja-JP"]] ]
    at DatabaseDriverNode.sqliteErrorToJsError (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/database-driver-node.js:23:18)
    at JoplinDatabase.sqliteErrorToJsError (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/database.js:36:30)
    at JoplinDatabase.<anonymous> (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/database.js:142:36)
    at Generator.throw (<anonymous>)
    at rejected (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/database.js:6:65)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
This one seems to indicate that it can't find command.js?
Uncaught (in promise) Error: Cannot find module './command.js'
Require stack:
- /Applications/Joplin.app/Contents/Resources/app.asar/index.html
    at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
    at a._resolveFilename (node:electron/js2c/renderer_init:2:2669)
    at Module._load (node:internal/modules/cjs/loader:908:27)
    at c._load (node:electron/js2c/node_init:2:13672)
    at s._load (node:electron/js2c/renderer_init:2:31018)
    at Module.require (node:internal/modules/cjs/loader:1122:19)
    at require (node:internal/modules/helpers:130:18)
    at codeMirrorRequire (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/editor/CodeMirror/pluginApi/codeMirrorRequire.js:46:23)
    at <anonymous>:10:22
    at <anonymous>:99:7
The slashcommands one returns a little later
/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/utils/dist/Logger.js:270 08:17:03: models/Setting: Could not save settings Error: Error: SQLITE_CONSTRAINT: UNIQUE constraint failed: settings.key: INSERT INTO `settings` (`key`, `value`) VALUES (?, ?): plugin-com.hieuthi.joplin.slash-commands.slash_definitions,[ ["datetime", "now", [ "yyyy-mm-dd HH:MM", "yyyy-mm-dd\"T\"HH:MM:ss" ] ], ["datetime", "date", [ "dd/mm/yyyy", "yyyy-mm-dd" ] ], ["datetime", "time", [ "HH:MM", "HH:MM:ss" ] ], ["datetime", "jdate", [ "yyyy年mm月dd日(ddd)"], { "dayNames": ["日", "月", "火", "水", "木", "金", "土", "日曜日", "月曜日", "火曜日", "水曜日", "木曜日", "金曜日", "土曜日"], "monthNames": ["一月", "二月", "三月", "四月", "五月", "六月", "七月", "八月", "九月", "十月", "十一月", "十二月", "一月", "二月", "三月", "四月", "五月", "六月", "七月", "八月", "九月", "十月", "十一月", "十二月"]}], ["string", "greet", [ "Hello", "你好", "Bonjour", "Hallo", "नमस्ते", "こんにちは", "안녕하세요", "Hola", "Xin chào" ] ], ["string", "task", [ "- [ ] " ] ], ["string", "todotxt", [ "```todotxt sort:default\n\n```" ] ], ["datetime", "todoa", [ "\"(A)\" yyyy-mm-dd " ] ], ["datetime", "todob", [ "\"(B)\" yyyy-mm-dd " ] ], ["datetime", "todoc", [ "\"(C)\" yyyy-mm-dd " ] ], ["datetime", "todod", [ "\"(D)\" yyyy-mm-dd " ] ], ["datetime", "todoe", [ "\"(E)\" yyyy-mm-dd " ] ], ["calendar", "calendar", [null,"en-US","ja-JP"]] ]
This one seems to be the outline plugin
/Applications/Joplin…/dist/Logger.js:270 08:17:03: models/Setting: Could not save settings Error: Error: SQLITE_CONSTRAINT: UNIQUE constraint failed: settings.key: INSERT INTO `settings` (`key`, `value`) VALUES (?, ?): plugin-outline.isVisible,1
    at DatabaseDriverNode.sqliteErrorToJsError (/Applications/Joplin…river-node.js:23:18)
    at JoplinDatabase.sqliteErrorToJsError (/Applications/Joplin…b/database.js:36:30)
    at JoplinDatabase.<anonymous> (/Applications/Joplin…/database.js:142:36)
    at rejected (/Applications/Joplin…ib/database.js:6:65)
And the command.js one returns again.
node:internal/modules/cjs/loader:1055 Uncaught (in promise) Error: Cannot find module './command.js'
Require stack:
    at <anonymous>:99:7
I'm ok with using v3.0.15 at the moment, but figured someone should be aware of this.
