Convert Text To New Note: 1.5.1
Get Notebook ID: 1.0.1
Insert Date: 1.0.1
Math Mode: 0.5.3
Note list and sidebar toggle buttons: 1.0.3
Note overview: 1.6.0
Quick Links: 1.2.4
Table Formatter Plugin: 1.2.1
Templates: 2.3.0
File system
I am on macOS 14.3 and node-v20.11.0
When starting Joplin (npm run start in dev mode or generating a dist and run the prod version) it hangs for about 15-20 seconds while only showing a white background. The CPU is at 100%, but nothing is logged in the dev console during that time.
I only upgraded my macOS today (10.14.6 -> 14.3). Before the macOS upgrade, I haven't seen this behavior at all.
Another possible source is the number of master keys present ā on some devices each master key adds about a second to the startup time. However, I would expect text to be logged to the dev console during this (see this issue).
There is only one dir and file in this dir. Removing it seems to fix the issue.
I deleted the dir in /Applications/Joplin.app/Contents/Resources/build/defaultPlugins and Joplin starts up in 2-3s instead of 15-20s.
This seems rather strange to me. Why does one .jpl file in a dir cause so much CPU load at start and how can this be fixed?
Personally I never liked the idea of bundled plugins, but I guess that people like it, so removing the bundled plugins doesn't seem to be an option.
Nope, I don't use encryption at all, thus no master keys...
It didn't, however, clear the defaultPlugins/ directory before doing a rebuild. On a machine that had done a build with a commit before13da286b55114438688f24b385bfca9f9f2df516, the build/defaultPlugins/ directory might still look like this:
Finally, when Joplin starts, it tries to load both plugin.jpl and io.github.jackgruber.backup.jpl. Attempting to load two default plugins with the same ID and different .jpl files seems to have caused the very slow startup issue.
