I am new to Joplin and am more than impressed by its layout and by the fact that sync via Nextcloud is possible. I tried to sync using WabDav on my Synology 218+ but that does not seem to work for some reason.
Unfortunately, I have a problem with the alarm settings. No matter how I try, the alarm on my Android phone simply won't work. I have set the following:
- Show notifications: on
- Alarm Notify: Alerting
- Pop on Screen: On
- Sound: Hangout Message
- Show Modification Dot: on
- Override Do Not Disturb: On
This is for Joplin 1.5.1 and my Android version is 10.
There is no sound, there is no popup, there is no dot, nothing.
Also, I have not found an option to snooze notifications: is such an option currently available?
Syncing between my Android Phone and the Desktop version for Windows (Joplin 1.5.12) works fine.
Many thanks for your help!
