Printing as pdf loses links
Good morning,
when printing a note containing links as PDF, I would like to open the links in the resulting file; but this is not possible; the resulting PDF doesn't let me open the links, apparently they are printed as text. I am printing from the md-editor which lets me open the links. What am I doing wrong resp. any way to change this behaiviour?
Cheers, kai.
Joplin 1.8.5 (prod, win32)
Client-ID: 005a2610d4c449ff86002adfe517ff3e
Sync-Version: 2
Profil-Version: 35
Revision: b28f087bb
@Kai welcome to the forum.
When you "print" to PDF are you using a PDF Printer installed on your system or using Right-Click Note > Export > PDF from within Joplin?
I just did a quick test and found that printing to a pdf creator does not create active links whereas exporting a note from Joplin as a PDF does.
@dpoulton
merci beaucoup for the quick response; that fixed t; works perfectly!
Cheers,
kai.
