I still can't recreate the problem. As you see mind:
Please let me know your system environment details.
@Sinacs Sure,
Joplin ver. 2.9.17
ReMoods ver. 3.5.0
os Win11
Your environment is just the same as mine. I need your help by following the below steps and take a screenshot for me:
help > toggle development tools, it will open a dev panelAfter that, you can click the top right close button within the dev panel to quit.
Thank you @Jackson , one more question, is this problem appear after update to ReMoods v3.5.0?
yeah, and I also did a clean install of both Joplin & ReMoods even removing all related folders...pretty frustrated, and no such issue when using the build-in Joplin theme
I'm sorry to hear about that. Actually, I'm still not so sure the exact problem because it seems only happening on your computer, but I can still find out a better way to rewrite some of the styles that might related to the selected text. I guess it might solve the problem for you.
For your case, below two things are important to check:
userchrome.css without any custom code that might affect the selected text style.hmm, understand it's hard to find out and debug too, thanks anyway, will keep posting if I found anything changed ![]()
And yeah, I don't have anything added to the userchrome.css and also the theme mode matches the built-in theme according to the installation guideline.
So, anyway, I will rewrite a part of codes, and I just need some time on it, and thank you again for supporting ReMoods! ![]()
This major update has rewritten all the codes to make general improvements. If you found that the content of your note doesn't display as usual after updating to ReMoods Theme V4, it might be due to the font settings didn't load the default values, please follow the below steps in case you meet the problem:
tools > options > ReMoods ThemeBase Font > DefaultMonospace Font > DefaultHeading Font > DefaultBase Font Size > 15Monospace Font Size > 14H1 Font Size > 170H2 Font Size > 140H3 Font Size > 130H4 Font Size > 120H5 Font Size > 110H6 Font Size > 100Math Notation Font Size > 0Show advanced Settings
Print Base Font > DefaultPrint Monospace Font > DefaultPrint Heading Font > DefaultPrint Base Font Size > 13Print Monospace Font Size > 12Print H1 Font Size > 180Print H2 Font Size > 160Print H3 Font Size > 140Print H4 Font Size > 130Print H5 Font Size > 120Print H6 Font Size > 110@Jackson I hope this update can fix your problem. Please let me know if it still doesn't work for you.
@joplin_user This update has all you needs.
Awesome! I have updated and will be testing ![]()
I am still testing, but it wanted to report that I am unable to enable the βNote List Panel - Enable auto-scroll effect for note list item.β The tick button is checked however the note name does not auto-scroll as I would expect. Am I misunderstanding what is supposed to happen?
I am on Joplin v2.9.17
I just checked it, and thx, I did make some mistakes, and I found the Print link href doesn't work too. They will be fixed in the next few days.
One more thing I just noticed, it seems that highlighting a word does not work. Using either the keyboard or cursor I cannot seem to highlight a word or sentence. This is occurring only in code blocks. Let me know if I can provide any further info around this to help.
Thank you!
Ok, it will be fixed.
Note: If you met any problems when updating ReMoods from v3 to v4, please read this.
To Chinese Language Users:
To improve the combination of Chinese & English note-taking experience, this update added a new member "GenSenRounded TW"(ζΊζ¨£ει«) as the default Chinese font. When compared with the "Chiron Hei HK", it appears more clearly in terms of the font strokes, especially in Traditional Chinese.
The "Chiron Hei HK" is already removed from the recommended font list, if you are enjoy using it you don't have to make any changes. But one exception, if you have installed both "Chiron Hei HK" & "GenSenRounded TW" on your computer, ReMoods will always use the "GenSenRounded TW" as a priority.
<span> font size will inherit from H1 when using it in H1 heading.@joplin-user, the directory icons have finally changed for you ![]()
Thank you! Testing it out now.
