Thank you!!! And just to clarify, it would be great to be able to toggle on or off the striped line in the plugin settings. I'm sure some users will still prefer it over the solid line.
How about the line width? Is it one of your concerns?
Sorry, just to clarify, do you mean the line width as the horizontal sizing or the vertical sizing of the line?
The height of the line. Currently, it is 3px.
Thanks, I think the height looks good with the current striped line.
Ok fine. I think you might need to wait for a week because I've made a lot of changes to the theme, but there is something still not stable, and that's why I didn't release any new updates in the past month. Whatever, I will release it as soon as possible. Thank you for supporting ReMoods!
Thank you for the plugin! I look forward to testing out the next release
ReMoods Theme v3.4.1 updates 2022-11-26
Note
In this release, ReMoods has moved all the font settings to the options page, so now you can configure everything right there! So, if you still have the older versions' font settings codes on your userstyle.css
and userchrome. css
, you should delete all of them.
Updates
Markdown Editor & Render viewer:
- Change: The default font combination has changed.
- Change: Added one more recommended font choice
Mulish
, it has a better reading experience thanMontserrat
. - Change: Due to the original font sizes difference between non-monospace and monospace, the font size grouping is also split into two parts
--usp-base-font-size
and--usp-monospace-font-size
. - Change: The recommended and default Chinese font has changed from
chiron hei text hk
tochiron hei hk
. - Change: For the customization needs, the font family has split into three parts
base font
,monospace font
, andheadings font
, you can now use your favorite font on headings to create a better personality style. - New: Added option for font settings.
- New: Added option to set the list text color equal to paragraph text.
- New: Added feature to auto-switch the
chiron hei hk
font weight fitting the theme mode. - Fix: Fixed the Chinese font weight invalid on headings.
- Fix: Fixed the inline code sizing.
- Style: Improved selected text styles.
- Style: Improved sub & sup text styles.
Markdown Editor:
- Change: Removed sub & sup text from smaller monospace font group.
Render Viewer:
- Change: Added the list token to the monospace font group.
- New: Added the scrollbar styles to the floating TOC list.
- New: Added option to turn off horizontal line twill pattern.
- Fix: Fixed the unexpected color of the list text.
- Style: Improved list styles.
Joplin UI:
- New: Added option to change the theme modes
Night
,Dusk
,Day
. - New: Added option to change theme color hue.
- New: Added colors to notebook panel folder icon. (Joplin v2.9.12+)
- New: Added option to hide notebook panel folder icon. (Joplin v2.9.12+)
- New: Added option to enable the bolder scrollbar for notebook panel & note list panel.
Plugins:
- New: Added support for Note Link System plugin.
Enhancement Plugin:
- Style: Improved footnote marker styles.
Note Link System Plugin:
- Style: Hide hash button for spoiler block title and content.
- Style: Hover the spoiler block title to show the hash button.
Spoiler:
- Style: Improved span title style.
I just want to say sorry to users who were confused about changing the font settings again and again. But the good news is v3 has already stepped into a stable version, so you don't have to worry about that anymore!
Please let me know if you have any ideas for improving this theme, I'll always be here and listen to your feedback!
Thanks all of you!
Huge thanks for the latest update @Sinacs!
I just noticed one thing: The horizontal line no longer shows as seen below when the solid line option is enabled:
I am seeing this behavior on macOS on Joplin versions 2.9.17 and 2.8.8. I also tried completely uninstalling and reinstalling the plugin, however that did not seem to make any difference. I can log an Issue on Github but wanted to see if you were seeing the same. Thanks!
Woops, I think it's my mistake, I will test it tomorrow. Thxπ
Thank you!! I just got a github issue logged for it.
Hi @Sinacs! I think I may have discovered a minor UI bug. As can be seen in the below screenshots, with the theme applied, the "In:Test" button is clipped at the bottom compared to Joplin without any theme applied:
Thanks @joplin_user , I'm less switching to the rich text editor, so it's not easy to find this problem.
One thing, after I switched to the Rich Text Editor and then create search on the Note List Panel input bar, it will jump back to the Markdown Editor immediately when loading the result, do you have the same situation?
Strangely I am not able to reproduce what you are seeing. I've tried searching with both the Markdown and Rich Text Editor but when clicking on the search result, the editor will remain the same.
I tested using Joplin v2.9.17.
Ok, it's helpful already, I will take a deep look at it.
Oh! I finally found that editor switching problem is a feature from another plugin Persistent Editor Layout
Nice!
Honestly, that plugin is quite useful, it can set the default view for each of your notes. I think you can try it if you haven't before.
ReMoods Theme v3.4.5 updates 2022-12-03
Render Viewer:
- Change: The paragraph text justify settings property will affect all paragraph text but not include list, checklist, footnote list and sticky notes.
- Change: The paragraph text justify settings property set default to turn off.
- New: Added option to enable list text justify.(default off)
- New: Added option to enable checklist text justify.(default off)
- New: Added option to enable sticky notes text justify.(default off)
- Fix: Fixed the horizontal line missing when changing to solid through settings. #12
- Fix: Fixed editor notebook title text shadow missing in dusk mode.
Rich Text Editor:
- Fix: Fixed the editor toolbar overlapping the notebook navigation button. #13
- Style: Improved editor footer pop up message bar colors.
Print/Export PDF:
- Fix: Fixed custom font settings properties didn't work as expected.
Joplin UI:
- Fix: Fixed the editor toolbar can't pop up when the notebook navigation button is displaying.
- Improve: Improved description in options menu.
- Style: Improved notebook folder icon colors. (Joplin v2.9.12+)
- Style: Added divider to notebook panel & note list panel.
