For the code block in Render Viewer, you should add the following code to your userstyle.css
#rendered-md .Joplin-editable > .hljs {
font-size: 14px ;
font-size: 14px ;
Thank you! I will add this and report back
Hi @Sinacs
It would be great to a compatibility with the wonderful bundle plugin and enhancement plugin from @SeptemberHX to have a nice dark theme with it !
Ya, I'm happy to do that if it's possible. You can check the below link and find out what plugins I'm already have planned to test in the future:
About the bundle plugin, I don't have plan to it, because I have installed it before but it's seems don't have any problem in the first basic try. So, it would be helpful if you can tell me where the exact problems on it.
Hi @Sinacs,
Here is some feedback on PDF export :
Here is an exemple (26.8 KB), to illustrate what I mean. Please let me know if I am missing something.
I have been using Remoods theme everyday for a few days now and I really like it ! You did a very good job. Thanks a lot !
Have a good day !
Note: This update requires updating your userstyle.css
and userchrome.css
manually, please copy the latest custom CSS codes from here and replace the old one.
--usp-base-font-size
.smaller monospace font size
has separated into three standalone properties for code block, markdown table syntax, and non-essential content. And now they are all available on the settings page.I will take a focus on the Print & Export PDF in the next update, thank you for the report! @Estar
Btw, I've created an issue for this: #10
Hi @Sinacs
Thank you for your answer. I take this opportunity to tell you how much I find this plugin project brings great novelty compared to the previous theme, in particular on masking toolbars. Itβs very nice.
For plugins, these are little things of readability. For example, there is a calendar in the plugin bundle and the days are not very easy to read.
Same for the integration of the History plugin in Bundle, there is not much contrast on the lines which connect the notes compared to the clear version.
And the same goes for certain tags colors of inline todo (which is also integrated).
In any case, in general, I think that the enhacement plugin deserves to be followed closely for the contributions it brings to the markdown editor... for example the change in title levels
Thank you in any case for your efforts. Beautiful day !
Thanks for the description @bepolymathe, but what I am considering is ReMoods can't change the CSS styles which belongs to the plugin private panel. What ReMoods can do is to style everything within the Markdown Editor and Render Viewer, or Joplin UI, but not the plugin private panel.
So, what I mean is I'm not understanding what I can do to the bundle plugin, because it seems everything is running within the private panel.
About the enhancement plugin, I've tested it last week but there were some problems that without solution. However, I've planned to test the enhancement plugin again because I think I've fixed a bug
that might be related to it. So, I will try to stay compatible with it if possible.
Hi @Estar ! I'm just testing on the Strong Text and Emphasize Text, but I can't recreate the problems. It seems without any problem in my PDF test result:
*for emphasize text*
and **for strong text**
.Hey @Sinacs - huge thanks for the work on the latest version of the plugin. I am still doing some testing but I think the updates may have actually fixed my issues with the code block text being too small. I'll follow up though if I see any issues.
I have also logged issue Feature Request: Modernize Notebook Expand Icon Β· Issue #11 Β· Sinacs/Joplin.Plugin.ReMoods.Theme Β· GitHub in hopes to uplift the notebook expand icon. I think this update would really help make the app/theme look much more modern. Let me know what you think
Thank you for your passion! I've replied to you on GitHub issue.
Yes, I am using the markdown syntax this way.
Nope, I did not customise anything. At least I don't think so My userstyle.css and userchrome.css are empty.
I guess that I missed something. The fonts maybe ? Or a conflict with another plugin. I will investigate a bit deeper when I can.
Thank you in any case for your help.
Adobe is fine, I think It might be the fonts problem, please make sure the font package you've installed is including italic and all font weights.
Yes, it was as simple as that ; It works perfectly fine now that I have my fonts properly installed...
Thank you again.
Great! My pleasure to help!
color:
/ background:
/ background-color:
)Great ! Thanks a lot !
Have a good one
Hey @Sinacs - I was curious, is it possible to toggle in settings the horizonal rule from the current striped line back to the standard line without any breaks? I've included a picture below of what I was hoping to revert back to a straight line with no breaks. Thanks!
Ok, I will go for it. It will be included in the next update.
