Plugin: Click-to-Copy spans
I wrote a plugin to make inline spans which, when clicked on, copy their contents to the user's clipboard. The spans are unobtrusively styled, and the plugin works on desktop and mobile. The spans do support displaying inline code, but otherwise do not display markdown within them - intentional since I use it to copy passwords, which may inadvertently contain valid markdown.
The basic format is that something like [[this]] in the editor will be rendered as a click-to-copy span in the webview which, when clicked, copies "this" to the user's clipboard. Any click-to-copy span that has its contents entirely encased in backticks, like [[`this`]], will have its contents displayed as inline code, while still click-to-copying (without the backticks).
There are settings to change the start and end tokens from [[ and ]] to whatever you may want to use.
GitHub: GitHub - ntczkjfg/joplin-plugin-click-to-copy-span
Full documentation:
Joplin Plugin - Click-to-Copy Spans
This Joplin plugin allows you to create inline click-to-copy text spans.
Version: 1.4.1
  • Open Joplin and navigate to Preferences > Plugins
  • Search for click-to-copy and click install
  • Restart Joplin
Uninstallation
  • Open Joplin and navigate to Tools > Options > Plugins
  • Find the Click to copy plugin
  • Press Delete to remove the plugin, or click the toggle to disable it
  • Restart Joplin
Click-to-copy spans
In order to create a Click-to-Copy Span, you can:
  • press on the Click-to-Copy Span toolbar button to create a template span, or
  • highlight text then press on the Click-to-Copy Span toolbar button to convert it to a span, or
  • manually type in the following format:
[[insert text here]]
You can additionally make the text within the span render as inline code by wrapping the entire contents of the span in backticks, like so:
[[`This will render as inline code, but still be click-to-copy`]]
As an alternative to the above, if you'd like inline code spans to always be click-to-copy without having to add the extra tokens, there is an option to enable this in settings.
If you double the start token, then the span will render its text as dots, to obfuscate things like passwords. If you double the end token, then the plugin will attempt to clear your clipboard after 15 seconds. When a span is rendered as a password, right clicking it will toggle between displaying dots and the actual text.
[[[[`This will show up as dots, and be erased from the clipboard 15 seconds after being clicked`]]]]
Use it for things you may frequently want to copy/paste:
With password obfuscation and forgetting:
With editor view enabled (default):
There is a settings page for the plugin in the Joplin options. There, you can:
  • Customize the start and end tokens away from the default [[ and ]]
  • Disable having the spans appear in the editor if you'd prefer only the raw text there
  • Choose if the start and end tokens are shown or hidden, when displaying spans in the editor is enabled
  • Enable or disable having inline code spans be click-to-copy in the webview and editor
Advanced
Custom styles
If you would like to style the collapsible blocks to your preference, use the following in your userstyle.css file, which can be accessed in JoplinOptionsAppearanceShow Advanced SettingsCustom stylesheet for rendered Markdown:
/* Styling of the click-to-copy spans */
.ctc {
/* Styling of the ctc-markdown, only when displaying ctc-spans in the editor, and not hiding markdown */
.ctc-markdown {
Notes
Acknowledgement
Thanks to the creator of the Joplin Spoilers plugin, whose code helped me build this plugin.
Other plugins
Check out my other plugins:
  • Collapsible blocks! Easily lets you create collapsible/foldable blocks that can hide their content from view.
  • Hotstrings & Hotkeys! Easily define custom hotstrings and hotkeys you can use in any note.
This is really neat!
Have you thought about extending the functionality to work in the markdown editor?
Thanks! I haven't, but I have now.
I'm pretty new to basically everything involved here: JavaScript, TypeScript, every relevant library - so every bit of progress is quite slow. But I can absolutely look into adding an option for that.
Well, you are doing great so far.
Having the click to copy would be a little tricky in the markdown editor because the user would also be clicking in the word to put the cursor there for editing.
My use case would be this… I only use the markdown editor along with the Rich Markdown plugin. This feature would be really useful when I'm documenting CLI processes because I often want to put a code snipit inline to copy later. I have the Better Code Blocks plugin installed so I can do what I want as a code block. But the inline copy would be great.
I'm thinking it's probably possible, based on what I've seen with another plugin - the Extra Editor Settings one, which displays a lot more markdown in the editor. The checkboxes in particular seem relevant: They appear in the editor as checkboxes as long as they aren't on the active line and, when clicked, can be checked or unchecked like usual, without moving the cursor. I'll be aiming to replicate something like that.
Thanks for your work on this. I found Click-to-Copy immediately useful. The kind of thing where one wonders, "How did I manage without this facility before?" :slightly_smiling_face:
Likewise, kudos on your collapsible blocks plugin, which also is a pleasure to use :+1:
This looks pretty useful
Could there be an option to change the syntax?
[[]] is wikilinks syntax, so could be interpreted as wikilinks if you ever export the markdown to an app that supports wikilinks (or if joplin ever added support for them)
@bwat47 You'll find that the ability to change that to something that suits you better is already available in the plugin settings
I've added this (click-to-copy spans in the editor) now, in version 1.1.1, which also fixes a bug someone reported about exporting notes to HTML/PDF. Thanks for the idea!
I did add an option to disable having the spans appear in the editor. I have them enabled by default. I'm curious to hear if anyone thinks they should be off by default?
I've updated to 1.3.0. This update adds a few things:
  • If you double the starting token, then the span will render obfuscated, so your password will show as "•••••••" instead of "hunter2". For spans like this, right clicking the spans will toggle between displaying dots and the actual text.
  • If you double the ending token, then the plugin will attempt to clear your clipboard 15 seconds after a span is clicked, as long as the clipboard hasn't changed in the mean time. Pairs well with the above.
  • I noticed in other threads that people don't always like when plugins hide markdown in the editor, so there is now an option to keep the markdown displayed when showing click-to-copy spans in the editor. This is disabled by default.
  • Fixed an issue where, if a click-to-copy span was in a checklist item, clicking the span would toggle the checklist item.
The README has been updated - and edited into the top message of this thread.
I’ve pushed version 1.3.3. It’s a minor update which allows setting the start and end tokens to a single backtick each, if you’d like to just use the plugin to make all inline code spans click-to-copy.
This update also fixes a previously unknown bug that made start tokens which didn’t begin with a special character not function properly. So now if you’d like to make your start and end tokens something like ‘ff’ and ‘gg’, for some reason - well, you can.
I’ve now pushed version 1.4.0. It’s a slightly less minor update.
This update adds two new options to the settings menu: One to make all inline code spans in the webview click-to-copy, and another to do the same in the editor. These options work using the default syntax for making inline code spans, not the custom markdown used by the plugin. So you will no longer have to do something like [[`this`]] or setting your start and end token both to a backtick to get click-to-copy inline code. Both of those options do still exist, but now there’s this too.
Note that it is possible to define inline code spans in the editor which span multiple lines (the webview then strips those newlines out). I opted not to support this in the editor as it was visually very unclear what would happen when spans were clicked. So any inline code spans in the editor which contain newlines will be correctly parsed by the plugin, but not made click-to-copy.
This update also handles some edge cases that occur when the start token and end token are identical better.
Feel free to let me know if you notice any bugs or regressions. Enjoy!
@ntczkjfg, this is a really nice improvement! :fire:
The best of both worlds: single lines of code automatically copy-on-click in both the markdown editor and the viewer (according to chosen settings), and we still get to continue using the square bracket fences (or other) for text that we don't want to look like code. This will save a lot of time. :slightly_smiling_face:
Thanks
Edit: Copy Code Blocks takes care of copying blocks of code, and doesn't interfere with Click-to-Copy Span—if anyone is looking for a solution for that
Could there be an option to hide the backticks when using the new option to make all inline code click to copy in the editor? (or maybe have it adhere to the existing "hide start and end tokens..." setting)
Sure - I’ll try to get that out as 1.4.1 some time later today. I’ll probably add a whole new option for it in Settings: I had it following the pre-existing option for hiding the tokens in development and kind of hated it so just ripped it out and made it always show. It’s no issue to add it back with its own option.
And @johano Thanks! :blush: While doing this update I actually planned to add an option to make code blocks click-to-copy too. It would have been easy to do so in the webview, but the editor had a lot more challenges with the logic, CSS, UI… and I just abandoned it before starting. I wouldn’t 100% rule out adding this to my plugin for the webview only at some point, but in the mean time I’m glad another plugin does the job well ^^
All set :saluting_face:
