Permission issue local file system
Joplin Server
I am running joplin server v2.13.3 (prod) in a docker container on debian and I'm trying to get file system storage to work via the appropriate environmental variable.
STORAGE_DRIVER=Type=Filesystem; Path=/my/path
Paths I have tried:
/var/data
/usr/local/data
/mnt/files
/mnt/data
No matter which path I use, I keep getting the following error on startup
[Error: Could not write content to storage: EACCES: permission denied, mkdir '/mnt/files/te'] {
app_1 | 22:16:04 0|app | errno: -13,
app_1 | 22:16:04 0|app | code: 'EACCES',
app_1 | 22:16:04 0|app | syscall: 'mkdir',
app_1 | 22:16:04 0|app | path: '/mnt/files/te'
This is in my docker-compose.yml
app:
        image: joplin/server:latest
        depends_on:
            - db
        ports:
            - "22300:22300"
        restart: unless-stopped
        volumes:
           - /docker/joplin/data:/mnt/files
        environment:
            - STORAGE_DRIVER=Type=Filesystem; Path=/mnt/files
            - STORAGE_DRIVER_FALLBACK=Type=Database; Mode=ReadAndWrite
Any help would be appreciated
I think what I did was to access the docker container as root:
docker exec -u root -it {{CONTAINER_ID_HERE}} bash
Then run:
chown joplin:joplin /mnt/files
Alternatively: It might also be possible to set ownership in the host, but I didn't try this:
chown 1001:1001 /docker/joplin/data
