Ordered List rendering in Joplin Markdown Guide?
in the Joplin Markdown Guide it says:
Ordered List
Markdown:
  1. Introduction
  2. Main topic
    1. First sub-topic
    2. Second sub-topic
  3. Conclusion
Rendered Output
  1. Introduction
  2. Main topic
    i. First sub-topic
    ii. Second sub-topic
  3. Conclusion
But this renders as the below for me:
  1. Introduction
  2. Main topic
    1. First sub-topic
    2. Second sub-topic
  3. Conclusion
Is this a typo on the Guide?
&/or can I get the i. ii. etc (or other) format(s) anyhow (that would be nice)
I just use the editing pane
Cheers!
Leigh
Joplin 2.12.18 (prod, linux)
Client ID: db5859eae4e74c52a26916ea37e9f7b0
Profile Version: 43
Keychain Supported: No
Revision: e47b908 (master)
Note Tabs: 1.4.0
Joplin displays the list the same for me as it does for you. I guess that the docs site is using a different stylesheet to Joplin??
I believe that you could use list-style-type in userstyle.css to modify how lists display.
All the different style types are shown here.
The type list-style-type: lower-roman;appears to be the one you are looking for.
Thanks @dpoulton !
OK,
I have to ask :rofl:
How the hell would I do that?
Is it possible to be able to select different styles for different lists and/or different levels?
To leave the top level as a number and change sub levels to roman you would be looking to change any ordered list that is itself an item in a list.
Off the top of my head, without testing it, in userstyle.css try:
li ol {
Thanks!
That does work (but only if I restart the numbering from 1. again for any indentations)
and so on ....
/* For styling the rendered Markdown */
li ol {
    list-style-type: upper-roman;
li li ol {
li li li ol {
    list-style-type: upper-latin;
li li li li ol {
    list-style-type: lower-latin;
Unless I have misunderstood what you mean, that is supposed to happen. A ordered list which is within a list is a new list and so starts from one. It enables you to have "legal-like" numbering such as: 3(a)(i)
Or, if you mean you have to physically type "1" to start a sub-list this is because with Markdown the item number has no real meaning apart from indicating what follows is part of a numbered list. That said, the number used for the very first list item does have significance as the renderer will count up from that number.
It is when the Markdown is rendered that auto-numbering is applied.
Personally, all entries in my lists start 1. like the "All same" example above, and I let Joplin sort out the numbering.
That's it, so its all working as it should then :+1:
ooooooow! How do I do this then? What would be really good would be cascading lists like 1.1.1.1 etc
Please?!
Sorry to build up your hopes! I only meant that you could have numerical, followed by lower roman, followed by lower alpha as you went down the list :slight_smile:
It may be possible (and it may be worth giving this forum a search for old posts) but it is beyond me!
Actually I think your example there looks cleaner and clearer than having 2.i.b. on the line for example!
I'm happy anyway,
Cheers! (as ever)
You can get the "1.2.1.3" rendering using:
ol { counter-reset: item }
li { display: block }
li:before { content: counters(item, ".") " "; counter-increment: item }
For example, using that in userstyle.css with:
1. first level 1 item
	1. first level 2 item
	1. second level 2 item
1. second level 1 item
		1. first level 3 item
		1. second level 3 item
renders as:
Cheers @dave_swofford !
