Hi there, currently there is a couple new fixes for OneNote importer in Joplin. Now we're awaiting for a new beta release (3.4.2) to incorporate those.
Here is the change
opened 09:23AM - 14 May 25 UTC
closed 09:04AM - 06 Jun 25 UTC
bug
desktop
high
import
### Operating system
### Joplin version
3.3.12
### Desktop version inf… o
Joplin 3.3.12 (prod, linux)
Device: linux, Intel(R) Core(TM) i3-4150 CPU @ 3.50GHz
Client ID: 4aa9e4458a1b403a94ed2a1b81896fee
Keychain Supported: No
Alternative instance ID: -
Revision: 4d790b6ff
Backup: 1.4.3
Extra Markdown editor settings: 1.11.0
Freehand Drawing: 3.0.1
Note list (Preview): 1.1.0
Quick Links: 1.3.2
Rich Markdown: 0.16.0
### Current behaviour
1. Attempt to import [OneNote archive](https://discourse.joplinapp.org/t/re-onenote-importer/45389?u=graphit0) (file requires Joplin team member auth)
2. Observe no notebook has been imported
### Expected behaviour
Import should either complete or display an error
### Logs
_No response_
Once it's out, please try it out and report back how it's working for your use case
Hi all, hope you're doing all right.
I'm attempting to help convert a friend's OneNote recipe notebook into a more open format, and I'm experiencing symptoms similar to those mentioned in this locked thread . This notebook is comprised of some tens of sections, and some hundreds of notes, but only two of the sections get converted successfully.
A transcript from the dev tools' console
/tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:798 Unrecognized feature: 'clipboard-write=(self)'.
setValueForProperty @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:798
/tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@joplin/utils/dist/Logger.js:259
10:55:15: InteropService_Importer_OneNote: Unzipping files...
10:55:16: InteropService_Importer_OneNote: Extracting OneNote to HTML
00529d2e:0xdd493 OneNoteConverter: Malformed OneStore data: not a legacy OneStore file
src/lib.rs:54:27
module.exports.__wbg_warn_1982e858bdcc0c42 @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@joplin/lib/node_modules/@joplin/onenote-converter/pkg/onenote_converter.js:309
$func956 @ 00529d2e:0xdd493
$oneNoteConverter @ 00529d2e:0x21234
module.exports.oneNoteConverter @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@joplin/lib/node_modules/@joplin/onenote-converter/pkg/onenote_converter.js:214
exec @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@joplin/lib/services/interop/InteropService_Importer_OneNote.js:54
await in exec
import @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@joplin/lib/services/interop/InteropService.js:274
processTicksAndRejections @ node:internal/process/task_queues:105
await in processTicksAndRejections
(anonymous) @ MenuBar.tsx:353
await in (anonymous)
click @ MenuBar.tsx:516
apply @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@electron/remote/dist/src/renderer/callbacks-registry.js:54
(anonymous) @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@electron/remote/dist/src/renderer/remote.js:353
(anonymous) @ /tmp/.mount_Joplin2UMglV/resources/app.asar/node_modules/@electron/remote/dist/src/renderer/remote.js:335
emit @ node:events:518
onMessage @ node:electron/js2c/renderer_init:2
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1228.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1229.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1230.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1231.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1232.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1233.JPG
src/lib.rs:83:27
await in exec
00529d2e:0xdd493 OneNoteConverter: Invalid file extension: .JPG, file: /home/me/.config/joplin-desktop/profile-zhnsfkzd/tmp/93d1f6e8a775693b36950f60dc3e9463/Recipes/IMG_1234.JPG
src/lib.rs:83:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
00529d2e:0xdd493 OneNoteConverter: rich text has no paragraph style
$func123 @ 00529d2e:0x62fe8
$func132 @ 00529d2e:0x6bd4f
$func180 @ 00529d2e:0x7c14c
$func365 @ 00529d2e:0xab3e0
$func239 @ 00529d2e:0x8e1ff
$func95 @ 00529d2e:0x55f84
$func204 @ 00529d2e:0x85351
$func50 @ 00529d2e:0x31ba7
$func117 @ 00529d2e:0x5e9d2
$func39 @ 00529d2e:0x1cc9a
$oneNoteConverter @ 00529d2e:0x1ea93
await in exec
00529d2e:0xdd493 OneNoteConverter: paragraph styling is missing
$func123 @ 00529d2e:0x64097
await in exec
00529d2e:0xdd493 OneNoteConverter: unexpected object type: 0x0. Using fallback style.
$func44 @ 00529d2e:0x26dea
$func123 @ 00529d2e:0x6421d
await in exec
src/lib.rs:67:28
await in exec
src/lib.rs:54:27
await in exec
$oneNoteConverter @ 00529d2e:0x2087a
await in exec
await in exec
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
src/lib.rs:54:27
await in exec
10:55:20: InteropService_Importer_OneNote: Extracting SVGs into files
10:55:20: InteropService_Importer_OneNote: Importing HTML into Joplin
10:55:20: InteropService_Importer_OneNote: Finished
10:55:30: SearchEngine: Updating FTS table...
MenuBar.tsx:355 Import result: {warnings: Array(0)}
10:55:33: Updating items_normalized from {updated_time: 0, id: ''}
10:55:33: SearchEngine: Updated FTS table in 1811ms. Inserted: 49. Deleted: 0
10:55:45: Preparing scheduled sync
The prospect of building a Rust library in addition to a massive TypeScript / JavaScript codebase on a low-resource system seems quite daunting to me. I had difficulty even getting msiemens/one2html to build standalone.
What's the best way to help here? Share the entire notebook with someone working on this part of the codebase? Wait for the next beta release to try out the recent fixes to the importer ? Report a bug to the upstream library's maintainer?
Hello, I'm closing this thread because for new issues we need new support tickets with full information to be able to help
