OneNote export to Joplin
For issue with the tool, please open a bug report on GitHub here.
Your issue can come from a problem with your office installation. As a first try and If possible for you, I would recommend to copy your notes on an other computer with OneNote installed, and try running OneNoteMdExporter on this other computer.
No, the app interact with OneNote to export the document into markdown. Software requirements are listed here.
Version 1.4.0 released :
Enhancements :
    Support of ==Text highlight==
    Attachement file name now based on unique identifiers (guid) to avoid name conflicts in specific situations
    Upgrade to DotNet 8
    Enhance startup error if Onenote crash. Fix #86
    Update Pandoc from 2.19.2 to 3.1.8
Bug Fixes
    "Could not find a part of the path" error (#93)
    Images not being exported for Notebook with apostrophe (#80, #90) => Thank you @armstrong-pv
Go further :
Alxnbl thank you so much, wonderful tool. Worked perfectly for me. I had to click on every note to make sure it synced up but once I did that it brought everything over with minimal fuss. Thank you!
It works very well! Thank you very much. I have now been able to move my notebook completely from OneNote and am no longer dependent on Microsoft.
:+1:Thank you for developing and sharing this tool! It works great and really helped me out!
Version 1.6.0 released here:
Enhancements :
  • OneNote links (onenote://) are now translated into markdown links. Except cross-notebook links and section links => big thanks @cosentino
  • Support of OneNote Tag translations like :white_check_mark::star:etc... => big thanks @Sudlon
  • Migrate from DotNet 8 to 10 (#132)
  • Update PanDoc from 3.2 to 3.8.3 (#129)
  • Highlight error message when an error occurs during execution (#112)
  • Add Spanish translation => thanks @pnoblejas
Bug fixes :
  • Images in table cells have incorrect syntax (#109)
