Joplin 3.4.1 (prod, linux)
Device: linux, Intel(R) Celeron(R) N4020 CPU @ 1.10GHz
Client ID: 44e3fdd0cdfd4c84b028b4fac399f990
Keychain Supported: No
Alternative instance ID: -
Revision: 24df674
Backup: 1.4.3
Favorites: 1.3.2
Home Note: 2.1.1
Hotfolder: 1.2.2
Journal: 2.0.0
Note list (Preview): 1.1.0
Note list and sidebar toggle buttons: 1.0.3
Quick Links: 1.3.2
Record: 1.5.0
RevealJS Integration: 0.15.0
Templates: 2.4.0
Rich Text Editor
About the TEMPLATES plugin...
"GitHub - joplin/plugin-templates: Create templates in Joplin and use them to create new notes and todos."
I tested all the built in variables: no problem.
BUT...
With custom variables : nothing happen...
Created note (I was asked nothing)
But this thing works:
I see no difference !!!
Maybe using 3 "-" with no space between and avoiding the line button...
In this case the strange behavior after the last "---" (bold thing and no more second line) is not a problem...
It remembers me: "Markdown Editor : the text becomes enormous after a dash : why?"
In fact there's a big "micmac" between the RTE and the MDE. Caracters seems OK but there are NOT.
SO : NEVER USE THE RTE in order to create a template and DON'T BELIEVE the MDV (MarkDown Viewer)
This is OK:
NO MORE HELP NEEDED. Thank you.
