OCR does not recognize Portuguese accented characters
Joplin 3.6.14 (prod, win32)
Device: win32, Intel(R) Core(TM) i5-14500T
Client ID: 81b9e799363b42f7ae82ac7662c29eb8
Profile Version: 49
Alternative instance ID: -
Sync target: (None)
Editor: Markdown
Revision: 7e2765a
Backup: 1.5.1
Freehand Drawing: 4.3.0
I'm having an issue with OCR in Joplin. The OCR works, but it does not correctly recognize Portuguese accented characters. Words containing characters such as ç, ã, á, é, ê, õ are recognized incorrectly. For example, words like "ação", "informação", and "licitação" are not indexed or extracted correctly.
To try to fix the issue, I have already:
  • Downloaded por.traineddata.gz (Portuguese language data).
  • Placed it in a local folder.
  • Configured OCR: Language data URL or path to point to that folder (not the file itself).
  • Cleared the OCR cache and re-downloaded the language data.
  • Restarted Joplin.
  • Confirmed that the OCR is running successfully.
Despite this, accented Portuguese characters are still not recognized correctly.
Is there anything else I should configure? Is there a known issue with Portuguese OCR or a specific version of the language data that should be used with Joplin?
Thank you!
