Npm start throws uncaught error
So I cloned the repo https://github.com/laurent22/joplin into my local machine (macOS Mojave) and then in the root I ran “npm install”
Then I went inside the ElectronClient Directory to run the Desktop app of Joplin.
But inside when I ran “npm start” the following error was thrown
Uncaught Error: Cannot find module ‘/Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/node_modules/sqlite3/lib/binding/electron-v7.1-darwin-x64/node_sqlite3.node’
Require stack:
  • /Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/node_modules/sqlite3/lib/sqlite3.js
  • /Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/lib/database-driver-node.js
  • /Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/lib/BaseApplication.js
  • /Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/app.js
  • /Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/index.html
    at Module._resolveFilename (internal/modules/cjs/loader.js:717)
    at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (reset-search-paths.ts:40)
    at Module._load (internal/modules/cjs/loader.js:622)
    at Module._load (electron/js2c/asar.js:717)
    at Function.Module._load (electron/js2c/asar.js:717)
    at Module.require (internal/modules/cjs/loader.js:775)
    at require (internal/modules/cjs/helpers.js:68)
    at Object. (/Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/node_modules/sqlite3/lib/sqlite3.js:4)
    at Object. (/Users/biswarupbanerjee/Desktop/Dream/joplin/ElectronClient/node_modules/sqlite3/lib/sqlite3.js:209)
    at Module._compile (internal/modules/cjs/loader.js:880)
I tried reinstalling node_modules yet nothing happened.
Any help will be appreciated.
Thanks
#gsoc-2020
Is sqlite3 is installed in your machine ?
Hi @sapsa
Yes, it is installed.
When I run sqlite3 I get this in my terminal:
SQLite version 3.24.0 2018-06-04 14:10:15
Enter ".help" for usage hints.
Connected to a transient in-memory database.
Maybe there is some version mismatch?
So I did a bit more research and found this:
“The latest version of SQLite always comes pre-installed within Mac OSX or macOS. You don’t have to download or install anything else, it’s located in the directory” (reference: https://tableplus.com/blog/2018/08/download-install-sqlite-for-mac-osx-in-5-minutes.html)
I have the same issue!
Tried to install from source on Ubuntu18.04 ARM64 machine...
Uncaught Error: Cannot find module '/home/michael/joplin/ElectronClient/node_modules/sqlite3/lib/binding/electron-v7.1-linux-arm64/node_sqlite3.node'
Require stack:
  • /home/michael/joplin/ElectronClient/node_modules/sqlite3/lib/sqlite3.js
  • /home/michael/joplin/ElectronClient/lib/database-driver-node.js
  • /home/michael/joplin/ElectronClient/lib/BaseApplication.js
  • /home/michael/joplin/ElectronClient/app.js
  • /home/michael/joplin/ElectronClient/index.html
    at Function../lib/common/reset-search-paths.ts.Module._resolveFilename (reset-search-paths.ts:40)
    at Object. (/home/michael/joplin…e3/lib/sqlite3.js:4)
    at Object. (/home/michael/joplin…/lib/sqlite3.js:209)
Hi @Tiemichael
Thanks for sharing your issue.
So are you also trying to start the ElectronClient ?
Yes, after ‘npm start’ I see the same picture you posted.
I have ~/joplin/ElectronClient/node_modules/sqlite3/lib/binding/node-v79-linux-arm64/node_sqlite3.node installed, but the folder should be ‘electron-v7.1-linux-arm64’
@techguybiswa @Tiemichael check this out
Tldr: you’ll most likely need to build you sqlite3 binary from source to get the library used here to use it
Hi @bedwardly-down,
Thanks for the link. I got some hints from it and researched more.
Now my issue is resolved.
I ran the following command:
"npm install electron-rebuild ./node_modules/.bin/electron-rebuild -w sqlite3 -p "
To know more as of how it is working I am linking the reference: https://stackoverflow.com/questions/38716594/electron-app-cant-find-sqlite3-module
@Tiemichael this solution might work for you too!
Glad to hear. I’m currently a volunteer comaintainer for the node-sqlite3 package that Joplin uses as a side project, so figured it might be of use. :wink:
Thank you!
Yes, it’s working for me!
Hey,
It also solved the same problem here! :muscle:
