I followed the build instructions. Building the tools and the Electron application using npm install worked fine.
npm install logs
[kct@catormac041 0 ~/work/joplin/Tools master {origin/master}|✔]$ npm install
npm WARN tools@1.0.0 No description
npm WARN tools@1.0.0 No repository field.
added 74 packages from 87 contributors and audited 95 packages in 2.331s
found 2 vulnerabilities (1 moderate, 1 high)
run `npm audit fix` to fix them, or `npm audit` for details
[kct@catormac041 0 ~/work/joplin/Tools master {origin/master}|✚1]$ cd ../ElectronClient/app/
[kct@catormac041 0 ~/work/joplin/ElectronClient/app master {origin/master}|✚1]$ rsync --delete -a ../../ReactNativeClient/lib/ lib/
[kct@catormac041 0 ~/work/joplin/ElectronClient/app master {origin/master}|✚1]$ npm install
> fsevents@1.2.4 install /Users/kct/data/work/joplin/ElectronClient/app/node_modules/fsevents
> node install
[fsevents] Success: "/Users/kct/data/work/joplin/ElectronClient/app/node_modules/fsevents/lib/binding/Release/node-v57-darwin-x64/fse.node" already installed
Pass --update-binary to reinstall or --build-from-source to recompile
> sqlite3@3.1.13 install /Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3
> node-pre-gyp install --fallback-to-build
[sqlite3] Success: "/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/node-v57-darwin-x64/node_sqlite3.node" is installed via remote
> electron@1.8.7 postinstall /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron
> node install.js
> Joplin@1.0.104 postinstall /Users/kct/data/work/joplin/ElectronClient/app
> node compile-jsx.js && node compile-package-info.js && node ../../Tools/copycss.js --copy-fonts
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ClipperConfigScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ConfigScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/DropboxLoginScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/EncryptionConfigScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/Header.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/IconButton.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ImportScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ItemList.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/MainScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/Navigator.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/NoteList.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/NoteStatusBar.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/NoteText.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/OneDriveLoginScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/PromptDialog.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/Root.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/SideBar.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/StatusScreen.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/Toolbar.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ToolbarButton.jsx...
Compiling /Users/kct/data/work/joplin/ElectronClient/app/gui/ToolbarSpace.jsx...
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-win@2.1.1 (node_modules/7zip-bin-win):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-win@2.1.1: wanted {"os":"win32","arch":"any"} (current: {"os":"darwin","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-linux@1.3.1 (node_modules/7zip-bin-linux):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-linux@1.3.1: wanted {"os":"linux","arch":"any"} (current: {"os":"darwin","arch":"x64"})
added 932 packages from 845 contributors and audited 4039 packages in 35.553s
found 12 vulnerabilities (2 low, 9 moderate, 1 high)
However, I’ve received an error when running yarn dist, but as far as I know this is not necessary for developing, but only to create a package. I will add the error here as well, although it’s just for completeness and should not disract from the real problem. (I won’t complain though, if somebody is able to help with the yarn issue either.)
yarn dist error
yarn run v1.7.0
$ node_modules/.bin/electron-builder
• electron-builder version=20.14.7
• loaded configuration file=package.json ("build" field)
• writing effective config file=dist/electron-builder-effective-config.yaml
• rebuilding native production dependencies platform=darwin arch=x64
• rebuilding native dependency name=fsevents
• rebuilding native dependency name=sqlite3
Error: /Users/kct/bin/node exited with code 1
Error output:
node-pre-gyp info it worked if it ends with ok
node-pre-gyp info using node-pre-gyp@0.6.38
node-pre-gyp info using node@8.11.1 | darwin | x64
node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/electron-v1.8-darwin-x64.tar.gz
node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/electron-v1.8-darwin-x64.tar.gz
node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/electron-v1.8-darwin-x64.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.13 and electron@1.8.7 (electron-v1.8 ABI) (falling back to source compile with node-gyp)
node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.13/electron-v1.8-darwin-x64.tar.gz
gyp info using node-gyp@3.7.0
gyp info ok
gyp info spawn /opt/local/bin/python2
gyp info spawn args [ '/Users/kct/.npm-global/lib/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args 'binding.gyp',
gyp info spawn args '-f',
gyp info spawn args 'make',
gyp info spawn args '-I',
gyp info spawn args '/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/build/config.gypi',
gyp info spawn args '/Users/kct/.npm-global/lib/node_modules/node-gyp/addon.gypi',
gyp info spawn args '/Users/kct/.electron-gyp/iojs-1.8.7/common.gypi',
gyp info spawn args '-Dlibrary=shared_library',
gyp info spawn args '-Dvisibility=default',
gyp info spawn args '-Dnode_root_dir=/Users/kct/.electron-gyp/iojs-1.8.7',
gyp info spawn args '-Dnode_gyp_dir=/Users/kct/.npm-global/lib/node_modules/node-gyp',
gyp info spawn args '-Dnode_lib_file=/Users/kct/.electron-gyp/iojs-1.8.7/<(target_arch)/iojs.lib',
gyp info spawn args '-Dmodule_root_dir=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3',
gyp info spawn args '-Dnode_engine=v8',
gyp info spawn args '--depth=.',
gyp info spawn args '--no-parallel',
gyp info spawn args '--generator-output',
gyp info spawn args 'build',
gyp info spawn args '-Goutput_dir=.' ]
gyp info ok
gyp info spawn make
gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
libtool: unrecognized option `-static'
libtool: Try `libtool --help' for more information.
make: *** [Release/sqlite3.a] Error 1
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/Users/kct/.npm-global/lib/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! stack at emitTwo (events.js:126:13)
gyp ERR! stack at ChildProcess.emit (events.js:214:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
gyp ERR! System Darwin 17.7.0
gyp ERR! command "/Users/kct/bin/node" "/Users/kct/.npm-global/bin/node-gyp" "build" "--fallback-to-build" "--module=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64"
gyp ERR! cwd /Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3
gyp ERR! node -v v8.11.1
gyp ERR! node-gyp -v v3.7.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'node-gyp build --fallback-to-build --module=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:925:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
node-pre-gyp ERR! System Darwin 17.7.0
node-pre-gyp ERR! command "/Users/kct/bin/node" "/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3
node-pre-gyp ERR! node -v v8.11.1
node-pre-gyp ERR! node-pre-gyp -v v0.6.38
node-pre-gyp ERR! not ok
error Command failed with exit code 1.
at ChildProcess.childProcess.once.code (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/builder-util/src/util.ts:252:14)
at Object.onceWrapper (events.js:317:30)
at Socket.stream.socket.on (internal/child_process.js:346:11)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at Pipe._handle.close [as _onclose] (net.js:567:12)
From previous event:
at runCallback (timers.js:794:20)
at tryOnImmediate (timers.js:752:5)
at processImmediate [as _immediateCallback] (timers.js:729:5)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/util/yarn.ts:150:27
at rebuild (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/out/util/yarn.js:234:18)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/util/yarn.ts:20:11
at Generator.next (<anonymous>)
at installOrRebuild (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/out/util/yarn.js:68:17)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:451:13
at Packager.installAppDependencies (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:415:70)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:365:20
at Packager.doBuild (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:341:39)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:317:52
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/graceful-fs/graceful-fs.js:99:16
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/graceful-fs/graceful-fs.js:43:10
at FSReqWrap.oncomplete (fs.js:135:15)
at Packager._build (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:294:133)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:290:23
at Packager.build (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/packager.ts:248:14)
at /Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/src/index.ts:51:40
at build (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder-lib/out/index.js:220:17)
at build (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder/src/builder.ts:234:10)
at then (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron-builder/src/cli/cli.ts:43:24)
at <anonymous>
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
This is the error I see in the console after running run.sh:
module.js:487 Uncaught Error: Cannot find module '/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64/node_sqlite3.node'
at Module._resolveFilename (module.js:485:15)
at Function.Module._resolveFilename (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/electron/dist/E…ctron.app/Contents/Resources/electron.asar/common/reset-search-paths.js:35:12)
at Function.Module._load (module.js:437:25)
at Module.require (module.js:513:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/sqlite3.js:4:15)
at Object.<anonymous> (/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/sqlite3.js:190:3)
at Module._compile (module.js:569:30)
at Object.Module._extensions..js (module.js:580:10)
at Module.load (module.js:503:32)
I found a related topic, but the proposed solution npm run pack did not work either.
npm run pack error
> Joplin@1.0.104 pack /Users/kct/data/work/joplin/ElectronClient/app
> electron-builder --dir
Error output:
gyp ERR! stack at ChildProcess.onExit (/Users/kct/.npm-global/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! command "/Users/kct/bin/node" "/Users/kct/.npm-global/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64"
gyp ERR! not ok
node-pre-gyp ERR! stack Error: Failed to execute '/Users/kct/bin/node /Users/kct/.npm-global/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/Users/kct/data/work/joplin/ElectronClient/app/node_modules/sqlite3/lib/binding/electron-v1.8-darwin-x64' (1)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sqlite3@3.1.13 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sqlite3@3.1.13 install script.
npm ERR! /Users/kct/.npm/_logs/2018-08-01T01_31_53_536Z-debug.log
at <anonymous>
npm ERR! errno 1
npm ERR! Joplin@1.0.104 pack: `electron-builder --dir`
npm ERR!
npm ERR! Failed at the Joplin@1.0.104 pack script.
npm ERR! /Users/kct/.npm/_logs/2018-08-01T01_31_53_589Z-debug.log
