Note overview
Add a space after sort: the sort: created_time DESC
That worked (also after "search:"). Thank you. This is such a useful plugin. But I will suggest the parser should probably be less picky about whitespace.
v1.4.3 (2021-05-17)
  • Fix: #12 Prevent note live update on Rich Text (WYSIWYG) editor, which leads to the deletion of the note overview code block.
Portable Joplin 2.0.2 (prod, win32)
Note overview v1.4.3
I have a problem with the plugin. All of a sudden, it stopped working.
I mean, nothing happens anymore when I run Tools > Create note overview, or Ctrl+Shift+O. It's simply dead, inerte.
I don't know when it happened, since I didn't need to check my overview notes these last few weeks.
An example :
I had this search for a long time
<!-- note-overview-plugin
search: -tag:*
fields: title, updated_time
sort: updated_time DESC
which was returning 5 notes.
Last week, I added a bunch of notes. Today, I wanted to find the ones with missing tags.
That's where I noticed that the overview note had not been updated. Same things for a few other overvieuw notes.
(Doing a simple search with Joplin, I know that I have now 10 notes without tags.)
What I've tried :
  • Create a brand new note, run the command, no effect.
  • Check the console : can't see any meaningful error, warning, but I can't be sure.
  • Delete the plugin, reinstall, no effect.
  • Run a new instance of Joplin Portable, install and run the plugin... and it works.
So something's wrong with my current installation ?
But at his point, I don't know where to look, what to do.
Any advice ?
Thanks.
@blank
Which Joplin version?
Are empty tables created?
The search return a result in the Joplin search field?
No table : if I run the plugin in a new note, the note stays totally empty. Nothing happens.
Yes, when I search for -tags:* in the Joplin field search, it returns 10 notes.
@blank
  1. Go in to you JoplinProfile\cache
  2. copy the folder io.github.jackgruber.note-overview somewhere outside the cache folder
  3. Delte the note overview plugin in the plugin settings
  4. ENter the path to the copied io.github.jackgruber.note-overview folder into Tools>Plugins>Development plugins>Development plugins under advanced settings
  5. restart Joplin
Now you should get a debug console for the plugin, do you see an error there, pr could you post the output?
Done. Here is the output from the console
plugin_io.github.jackgruber.note-overview.js:279 Note overview plugin started!
DevTools failed to load SourceMap: Could not load content for file:///C:/Users/admin/AppData/Local/Temp/1sqvHInucrYkNtoPvX7AfEW3A6Q/resources/app.asar/services/plugins/sandboxProxy.js.map:
plugin_io.github.jackgruber.note-overview.js:279 Set timer
plugin_io.github.jackgruber.note-overview.js:279 Run create note
Could you please export one of your overview notes, because the plugin can't find any overview note.
Sure, I made a jex export of one note, but then ? You want me to send it ? If so, where ?
Correct
You can post the JEX her or send me a direct message with the file.
OK we have found a bug, according to the showCompletedTodos setting.
OK, so I just re-enable Show completed to-dos and the plugin runs again with no problem.
Thanks a lot @JackGruber ! Impressive follow-up !
What version of Joplin is required for this plugin? I haven't been able to find that requirement documented anywhere - can you point me in the right direction?
Joplin 1.7.11 (prod, linux)
Client ID: xxx
Sync Version: 2
Profile Version: 34
Keychain Supported: No
Revision: f560563 (master)
Thank you!
From version 1.4.0 is the required version from joplin 1.8.1
Due to a bug a plugin can be updated to a not compatible version.
You can install the v1.3.4 from the GitHub release page or update your Joplin to the pre-release version.
Gotcha, thanks. I'll wait; can't afford to jeopardize my notes on pre-release software.
Just FYI, the current stable release of Joplin is v1.8.5. It was moved out of pre-release about 2 weeks ago
Turns out I had the older AppImage somewhere, and still was using the old shortcut. Thanks for pointing that out!
Thanks, I have completely overseen the release v1.8.5.
Dears,
still love this plugin, gives me daily joy and ease of mind.
One question though: How could I search my notes for "Meetings today" and "Meetings tomorrow and in the near future"?
Unfortunatley, with notes, I have no field "due_date" available. I usually write the date/time in the title, like "210601 | 0845-0900 | Install Joplin".
This code:
<!-- note-overview-plugin search: tag:meeting title:210601 fields: notebook, title sort: title ASC -->
gives me today's meetings.
And this code filters according to day, but also includes today's meetings:
search: tag:meeting title:21060*
sort: title ASC
Any ideas how to separate these two?
Cheers,
CoarseGrater
