Note overview
Is it possible to also see who posted it? we are using for sync joplin server and we would like to see who edited it last
I have one question / request ( I know that is not the businees of your plugin so i know the answer is no but...i need to try it ) I have a note as full agenda using all the posibilities that your plugin have (search for today, tomorrow, this week, birthdays, calls, events, etc...using humanize dates, alert 24 hour of event going to due with other color , create bar menus with no count ...) and repetitive task with tag like daily weekly mothly quarterly... but this is the point where i have a little problem. All repetitive task must update manualy (there is no problem with daily becouse i add a time tag and create a note with your search by this tags 8:00 9:00... creating adicional note as a daily events, i think that is not posible search by hours or a period of hours. In the case of weekly etc this need to change due date manualy) In other hand your plugin see the due date past with diferent colors ( So when a due date past the plugin add red color to due date. <font title=" " color="red" ) so i“m asking if you can plan that adittionaly the events notes with any special tag (weekly...) could be modified the due date ( get due date and push new due date sum weekly notes: day +7, monthy notes: month + 1 , yearly notes: year +1... when refresh search and note go to red (this will be a workaround for repeat alarm) ) I“m sure that is not easy as i write and is not the correct use of your plugin but i need to ask it. Anyway thanks again for your work that help me a lot to don“t waste time and have all ordered and in one place.
Last question. Do you have any plan to be available your plugin in android?
