Is there a way to view information about a note, such as date updated, created, etc? I was sure when I first started using Joplin one of these platforms had an option to view metadata but I can’t find it now.
On desktop you can view those things by pressing the “i” button. See the screenshot below
Also on mobile you can open the menu from a note (The three dots in the top right) and select “Show metadata”
Found it! Need to have Advanced Options set in Configuration.
I forgot I had that set! Glad you could find it on your own!
