Really liking tis app, thanks big time!
Tried the web clipper in Firefox and grabbed a page with a host of links and pictures - it grabbed it all. pretty slick. However, when exporting to PDF the pictures and underlined hyperlinks were present, but the links were not active.
Are there plans to make active links port over to PDF or am I missing a step?
No, it should work out of the box. Can click on a link in your clipped note in the preview pane (the right one)? If yes, it should also work after exporting it to PDF. If not, there might be an issue with the clipper.
Can confirm. I can click on the link in the preview pane, but after exporting to PDF the link is no longer active (though still blue and underlined as if it were a hyperlink).
Hi. I hover my mouse over the hyperlink in Joplin’s display window of the note, a bubble appears of the web page. If I right click on the note to export to PDF, the hyperlinks “appear” with underline/blue font, but will not launch a web page.
I created the markdown page using both the Firefox and Chrome web clippers. Seem to work in Joplin in either case, but it’s after the export to PDF where it stops.
Happens if I create a hyperlink manually in Joplin. New Note, created a link to google.ca, export to Macos Mojave desktop…Use either Preview or Books to view the PDF - same results with hyperlink present without activity from clicking on where the hyperlink is.
Huh. When I sent the PDF created by Joplin to my iPhone, it worked once from the app it imported to, Documents 6, but stopped working after the one time it opened a page from a web link. Strange.
Signed up just to mention this. I thought the issue was closed with no upstream (electron) fix. But when i recently tried another electron based note app and copy-pasted my Joplin MD into it, including inline links, they exported to PDF as clickable hypertext.
Absolutely love Joplin, and how it has super functional and organised interface. Thanks for all the great work.
edit: What i have just noticed is that URLs, plainly typed, ie http://www.example.com, will be exported as clickable hypertext.
I’m a new Joplin user, and I LOVE it. But today, I tried to export the note as a pdf, all links (to a web or the toc) are inactive. I also saw that the problem has been closed in Apr 2019 and it seem has been solved. I’m using v1.0.233 which is realsed in Aug 2020 on WIN10. I don’t know why it doesn’t work.
Sorry, I was merely commenting to yw3a14's comments that the links were broken in PDF, I recalled it happened last year. I responded from my mobile device, I hadn't tested their statement was in fact happening again, just interacting a time frame it happened.
This is still an issue.
I export a document to PDF or use Print and Print to File and all the hyperlinks are no longer hyperlinks. They look like they should be, but they are not.
Joplin 3.2.13 on Linux. It's been like this for some time, I just hadn't gotten to sending in the error report yet.
I'm on Fedora 41 and Joplin 3.2.13. 3.3.5 is a pre-release. I hope it is truly fixed when I upgrade whenever 3.3.z comes out, but in the meantime, it doesn't function. Maybe there is a plugin conflict? What plugin would twiddle that particular bit though?
All links are de-linked for some reason. I will troubleshoot. I suspect there is some plugin doing this. I can't imagine what else would. I have some heavily customized userstyle.css, but nothing ... weird. I dunno.
