Nextcloud and Joplin: synchronization problem
Joplin 3.5.13 (prod, win32)
Appareil : win32, AMD Ryzen 9 9950X3D 16-Core Processor
ID client : d992038eac28495f8653876423239224
Version de Synchro : 3
Version du profil : 49
Trousseau supporté : Oui
ID d'instance alternatif : -
Révision : 0c1511f
Backup: 1.5.1
Freehand Drawing: 4.2.0
Pages Publisher: 1.7.1
Nextcloud
Hello. I have a synchronization problem with my new installation of Nextcloud. All worked with Joplin with my old hosting on a mutualized server with Infomaniak.
This time, I have installed Nextcloud on my dedicated server.
Well, I have this message in Joplin interface: Capture d écran 2026 03 18 170221 hosted at ImgBB — ImgBB
What's wrong in my installation or my Joplin configuration?
Thanks.
(first message)
Did you copy the data from the old server? That can cause problems. It is safer to start with a clean slate (don’t copy anything to the new server) then create a new profile, import a jex backup of your data and then sync this data onto the new server.
A bit more details about starting over are here: How to fix synchronisation issues and start over
It was a template problem with my control panel. It works now.
Have a nice afternoon.
