Need help regarding finding issues
Hi @PackElend, Hi @rullzer,
I tried to find issues for the ElectronClient (Desktop labeled) that I can work on. But people have already commented that they are working on that issue or want to work on that issue. As it’s first-come-first-serve, what should I do? #gsoc-2020
Please tell me if I’m missing something. Thanks.
Hi @gittysachin
Try searching for more issues. If there are no issues left, you can create of your own. Before that, ensure that the issue doesn’t exist already.
Thanks @Jayashree-panda,
I absolutely forgot that I could find create a issue if it doesn't exist. :grinning:
It’s ok @gittysachin
Go ahead😁
For GSoC, it’s ok to also come up with small thing you see you can improve in the app. Also have a look at the bug reports, in case you can fix of some of them.
Thanks @laurent, I’ll try to do the same.
