A few of my notes have weird icons at the far right of the title: for example a tickbox or a pie chart (this is a depiction of a ticked, round checkbox, not the functional checkbox you get in todo notes).
Any idea what they are?
The only non-standard plugin I use is favourites, but those notes are not favourites
they show for any notes that have task lists
if all task list items in the note are checked, it will show a checkbox. Otherwise, it will show an icon indicating the not completed/completed number of task list items.
if desired, this can be disabled under Options | Appearance | Show checkbox completion chart in note list
Oh I see, makes sense. I don't actually use task lists, so that must have been random sequences in the text. I'll follow your suggestion
