Mermaid output window
I've noticed a slight problem with Mermaid output:
Mermaid output is always rendered to 100% of the viewer. This is a serious problem when the diagram is huge.
I'd suggest to add a viewer window when double-clicking the diagram. This window should have 2 options:
  • allow to set the canvas size (not the window) thus the window must have scrollbars
  • button to make canvas size equal to the window size
The window itself should be resizable and remember size and position.
I had the same problem as you: It's hard to read when the diagram is huge.
I created a thread to discuss enhancements to mermaid.
