Firstly, thank you for adding Mermaid support, this is amazing.
I was going through the features Mermaid offers, and I noticed the interaction section where they discuss adding Javascript callbacks to nodes in the diagrams.
I created a note with the contents:
<script>
var callback = function(){
alert('A callback was triggered');
</script>
```mermaid
graph LR
A --> B
click A callback "Tooltip"
The graph renders, but in the built-in viewer, neither the tooltip nor the callback works. When exported to HTML, the tooltip appears, but the callback does not work.
Furthermore, if I make the handler a redirect, similar to the example (e.g. click A "http://google.com" "Tooltip"), the rendered note disappears in the built-in viewer when the node is clicked, supposedly because of the redirect. Then, I cannot find an easy way to re-render the note, short of restarting the application. When exported to HTML and opened in a browser, the redirect works as expected.
Am I making a mistake somewhere, or are these things not fully supported yet? If the latter, is this planned to be supported in the future?
