Mac Renders UI Unexpectedly and Oddly
Joplin has been a great solution. Thank you. I'm having difficulty with the way Joplin renders on one Mac. Here is a screen shot:
The white space on the left and the right is unexpected.
Mac 12.5.1
Joplin 2.8.8 (prod, darwin)
Client ID: d9c21d6c0ca84abaa678e6b4fad5ff3b
Profile Version: 41
Revision: c2a6a13
About three weeks ago I switched from Dropbox to AWS. My corporate security was filtering dropbox poorly. AWS worked great.
I have another Mac client, it's Intel, but otherwise it's configured similarly. No problems there. iOS is working well too.
  • Debug/console warning:
DevTools failed to load source map: Could not parse content for file:///Applications/Joplin.app/Contents/Resources/app.asar/gui/note-viewer/pluginAssets/mermaid/mermaid.min.js.map: Unexpected end of JSON input
Nothing else stood out.
  • Safe mode rendered in the same way.
  • dev mode opens as expected. No notes of course. :slight_smile:
  • I can reliably close and open Joplin in "normal" mode and get the same result.
I uninstalled/reinstalled the app. The situation did not change.
My next move was to delete the data and re-sync everything. But I was hoping for something less drastic.
Any other data I can collect for you, I'm happy to do it.
Thanks
Uhh.. never mind? Error existed between my keyboard and seat.
Errant custom css attempt. I did that a while back, it just hit... odd.
At any rate removing them from the mix, fixed it. You can close this.
Thanks.
