Lock note - Don't allow changes
It would be great if I could lock notes when they are "finished" so I cannot accidentally modify it anymore.
Do modify a note again, you need to unlock it first.
If it's just accidental modifications you're worried about: I use the "Persistent Editor Layout" for this.
You can tag a note, and the plugin then makes sure it's always opened in Viewer mode. That way you have to manually toggle the mode to make it writable.
Thanks. I will try this solution. But it works only if the user installs the plugin and shares notebooks are easily modified anyway.
Yeah. it's a very local solution. I sync between four devices right now. I really like this plugin, but the "view-only" behavior it enables is merely a side effect of what it's real purpose is.
That being said, I am glad to have stumbled onto the plugin via this comment thread.
