Lock Joplin
Desription
Joplin will ask to enter the passcode when open it.
Reason
Keep the local notes safe.
Thank you.
This subject comes up very often and has been discussed at length on this forum. Have a search for "PIN", "app password" or "passcode" or something like that. There will probably be quite a bit to read :slight_smile:
This is the entry in the FAQ about Joplin not having a password lock.
I see, actually I searched with keyword lock, but didn’t find what I need. I should use other keywords.
My mistake.
There is a new plugin named joplin-plugin-app-locker. Please try it. I hope it help you.
