Location of Plugin settings
Can someone please let me know where Joplin stores Plugin settings on a Linux install? I'm looking for the file where they are stored, not the location they are set within the UI. I can't find them. Thanks.
Pretty sure its in the settings table of the database in ./config/joplin-desktop. Not sure how much use they are.
It depends, but dearaxa is right, to plugin settings from the configuration gui are stored in the database under settings with the pluginname and setting name as key, but the plugin developer can also save some settings in json files or somthing else.
Thanks to both. This was really helpful.
