Links to Headings
Hi
I am using this post as a guide to try to make a link to the following heading
# MSc Theses
like this:
[MSc Theses](#MSc-Theses)
It displays correctly in the rendered pane, but clicking on the link does nothing
What have I done wrong?
Thanks
Sorry to answer my own post, but this may help further users searching, so ...
Anchor tags are parsed in lower case, so the below works:
[MSc Theses](#msc-theses)
i.e. keep link in lower case.
I had been searching for a while before posting here, but only found the above afterwards, honest!
You can also use this plugin and enable LH options for this purpose
