Joplin 3.2.13 (prod, win32)
Client-ID: ddb12b4ba2104bb9b01d9df83475d102
Sync-Version: 3
Profil-Version: 47
Revision: a898e17
Backup: 1.4.2
Katex Input Helper: 1.0.7
Nextcloud
Hi, I have installed the Katex-Input-Helper.
When I use the Katex Dialog from the tools menu I get a window with the following message:
"Editor is downloading...
Thank you for your patience.
If the editor is not loaded properly in up to five seconds, you can try to reload by closing and re-opening the dialog. This will probably happen after a new installation of the plug-in."
After a few secons, this pop-up comes:
The Katex Input Helper could not be opened properly.
(Error: Mhchem not loaded).
Please close it and open it again).
I have re-installed the plugin already and restarted Joplin.
I think I miss something here.
Although, the Katex test dialog opens correctly.
Anyone know what I can try?
