Some small plugin JopPomidorko ![]()
JopPomidorko
English
JopPomidorko is a productivity plugin for Joplin that brings the classic Pomodoro Technique right into your note-taking workflow. Track focused work sessions, link them to specific notes, and see detailed statistics about your productivity — all without leaving your favorite note app.
- Full Pomodoro flow — work intervals, breaks, pauses, stops, and completion tracking
- Rich statistics — grouped by day, with totals for sessions, completions, pauses, and total focused time
- Note linking — each pomodoro is linked to the currently selected Joplin note (title, UUID, URL)
- 9 built-in languages — English, Русский, Deutsch, Español, Português, Français, Српски, 中文, 日本語
- Instant language switching — change the UI language on the fly, no restart needed
- Customizable design — pick gradient colors for the timer and statistics blocks
- Custom translations — edit any string through a built-in table
- Import / Export translations — share your translations as JSON files with others
- Sound notifications — synthesized chord when a session ends (Web Audio API, no external files)
- Display modes — four ways to view the timer (remaining, elapsed, and both with totals), switchable by click
- Fully configurable — work/rest intervals, button visibility, confirmation dialogs
- Three independent accordions — Timer, Settings, Statistics, and Translations can each be collapsed
- Download the latest release:
joplin.plugin.jop-pomidorko.jpl - In Joplin: Tools → Options → Plugins → Install from file
- Select the downloaded
.jplfile - Restart Joplin
- Click the clock icon on the note toolbar to toggle the panel
Build from source
Clone the repository, install dependencies and build the plugin:
git clone https://github.com/yourusername/jop-pomidorko.git
cd jop-pomidorko
npm install
The built .jpl file will appear in the project root.
- Open the panel — click the clock icon on the note toolbar
- Click "Start" — a dialog asks for a task name (auto-filled from the current note)
- Work — the timer runs in the background, counting up (or down)
- Finish / Pause / Stop — control the session with the action buttons
- Review stats — expand the Statistics accordion to see history
Each session is recorded with:
- Timestamp
- Action (start / pause / resume / stop / complete)
- Linked note title and UUID
- Duration worked
Configuration
| Setting | Default | Description |
| Work interval | 25 min |
Length of a focused work session |
| Rest interval | 5 min |
Break duration (future feature) |
| Display mode | Elapsed of Total |
Click the timer to cycle through modes |
| Timer background | #0052CC |
Primary color of the timer gradient |
| Statistics background | #0052CC |
Primary color of the stats gradient |
| Interface language | Auto |
Falls back to Joplin's locale |
| Warn on Pause | off |
Show confirmation dialog |
| Warn on Stop | on |
| Play sound | on |
Web Audio synthesized chord |
Translations
JopPomidorko ships with 9 languages. To contribute or customize:
Edit inline. Open the Translations accordion, choose a language, edit any string, click Save.
Export. Click Export JSON to download all your translations.
Import. Click Import JSON and pick a file from someone else. Translations are merged, so you can combine packs.
Translation file format:
"plugin": "jopPomidorko",
"version": 1,
"translations": {
"ru": {
"timer.btn.start": "Старт",
"timer.btn.stop": "Стоп"
Empty values fall back to English, so partial translations work fine.
Technical Details
- Plugin API: Joplin Plugin API v1 (manifest_version 1)
- Runtime: Node.js 18+ (plugin host) + Chromium webview (UI)
- Build: Webpack 5 + TypeScript + ts-loader
- Sound: Generated via Web Audio API (no bundled audio files)
- Storage: Joplin settings API (encrypted at rest)
Contributing
Contributions are welcome! Ideas:
- Complete translations for
de,es,pt,fr,sr,zh,ja - Long-break cycles (every 4 pomodoros)
- Daily / weekly goals
- Export statistics as CSV / Markdown
Please open an issue before starting major work.
MIT — free for personal and commercial use.
Credits
- Inspired by the Pomodoro Technique by Francesco Cirillo
- Built for the wonderful Joplin note-taking app
- Design language influenced by Atlassian Design System
Made with care for focused minds
Русский
JopPomidorko — это плагин продуктивности для Joplin, который привносит классическую технику «Помидоро» прямо в ваш рабочий процесс с заметками. Отслеживайте сессии сфокусированной работы, связывайте их с конкретными заметками и смотрите подробную статистику — не покидая любимое приложение.
Возможности
- Полный цикл Помидоро — работа, перерывы, паузы, остановки и отслеживание завершения
- Подробная статистика — группировка по дням, итоги по сессиям, завершениям, паузам и общему времени фокуса
- Привязка к заметкам — каждый помидоро привязывается к текущей заметке Joplin (заголовок, UUID, URL)
- 9 встроенных языков — English, Русский, Deutsch, Español, Português, Français, Српски, 中文, 日本語
- Мгновенная смена языка — интерфейс переключается на лету, перезапуск не нужен
- Настраиваемый дизайн — выбирайте цвета градиентов для таймера и статистики
- Свои переводы — редактируйте любую строку через встроенную таблицу
- Импорт / Экспорт переводов — делитесь переводами через JSON-файлы
- Звуковые уведомления — синтезированный аккорд по завершении (Web Audio API, без внешних файлов)
- Режимы отображения — 4 способа показа таймера, переключаются кликом
- Полная настройка — интервалы, видимость кнопок, диалоги подтверждения
- Три независимых аккордеона — Таймер, Настройки, Статистика и Переводы сворачиваются независимо
Скриншоты
Установка
- Скачайте последний релиз:
joplin.plugin.jop-pomidorko.jpl - В Joplin: Инструменты → Параметры → Плагины → Установить из файла
- Выберите скачанный
.jplфайл - Перезапустите Joplin
- Кликните на иконку часов на тулбаре заметки, чтобы показать/скрыть панель
Сборка из исходников
Склонируйте репозиторий, установите зависимости и соберите плагин:
cd jop-pomidorko
npm install
Готовый .jpl файл появится в корне проекта.
Использование
- Откройте панель — кликните по иконке часов на тулбаре заметки
- Нажмите «Старт» — появится диалог с названием задачи (автозаполнение из текущей заметки)
- Работайте — таймер идёт в фоне
- Завершить / Пауза / Стоп — управляйте сессией кнопками
- Изучите статистику — раскройте аккордеон «Статистика»
Каждая сессия сохраняется с:
- Отметкой времени
- Действием (старт / пауза / возобновление / стоп / завершение)
- Названием и UUID связанной заметки
- Продолжительностью работы
Настройки
| Параметр | По умолчанию | Описание |
| Интервал работы | 25 мин |
Длительность сессии фокуса |
| Интервал отдыха | 5 мин |
Длительность перерыва (в планах) |
| Режим отображения | Прошло из Задано |
Клик по таймеру циклически меняет режим |
| Фон таймера | #0052CC |
Основной цвет градиента таймера |
| Фон статистики | #0052CC |
Основной цвет градиента статистики |
| Язык интерфейса | Авто |
Берётся из настроек Joplin |
| Подтверждать паузу | выкл |
Показывать диалог подтверждения |
| Подтверждать стоп | вкл |
| Проигрывать звук | вкл |
Синтезированный аккорд |
Переводы
В JopPomidorko встроено 9 языков. Как внести вклад или настроить:
Редактировать в интерфейсе. Откройте аккордеон Переводы, выберите язык, измените любую строку, нажмите Сохранить.
Экспорт. Нажмите Экспорт JSON — скачаются все ваши переводы.
Импорт. Нажмите Импорт JSON и выберите файл от другого пользователя. Переводы объединяются, так что можно собирать паки.
Формат файла переводов:
"version": 1,
"translations": {
"ru": {
Пустые значения подставляются из английского, поэтому частичные переводы работают отлично.
Технические детали
- Среда выполнения: Node.js 18+ (хост плагина) + Chromium webview (UI)
- Сборка: Webpack 5 + TypeScript + ts-loader
- Звук: генерируется через Web Audio API (нет бандленных аудиофайлов)
- Хранение: Joplin settings API (в зашифрованном виде)
Участие в разработке
Приветствуются любые идеи:
- Полные переводы для
de,es,pt,fr,sr,zh,ja - Циклы с длинными перерывами (каждые 4 помидоро)
- Ежедневные / еженедельные цели
- Экспорт статистики в CSV / Markdown
Перед началом большой работы откройте issue.
Лицензия
MIT — свободное использование в личных и коммерческих целях.
Благодарности
- Вдохновлено техникой «Помидоро» Франческо Чирилло
- Сделано для замечательного приложения для заметок Joplin
- Визуальный язык вдохновлён Atlassian Design System
Сделано с заботой о сфокусированных умах
