Joplin Tags not showing in Inline Tags Navigator
Joplin 3.3.13 (prod, linux)
Device: linux, 13th Gen Intel(R) Core(TM) i7-13620H
Client ID: 3e0cb3f00e334454bf784cb1dfd6f55a
Keychain Supported: No
Alternative instance ID: -
Revision: 144ed59
Backup: 1.4.3
Bidirectional Links: 0.2.1
Freehand Drawing: 3.0.1
Graph: 1.1.0
Inline Tag Navigator: 2.4.0
Inline tags: 1.3.0
Templates: 2.4.0
Unless I missed something, it seems that the Joplin (régular) tags are not detected by the Inline Tags Navigator (which kind of make sens juste reading the name of the plugin).
I updated multiple notes with Joplin Tags, I can see them at the bottom of the note, as well as on the left menu (at the bottom of all the notebooks), but I can't see/find/seach these in the Inline Tag Navigator.....
Does it mean I have to go back in each note to add Joplin tags inline, so they can be visible in the Inline Tag Navigator ?
Is there a way to add the Jopin Tags to Inline Tags, so they can be found/searched in Inline Tag ?
Hi @K0rb3n, welcome to the forum!
You may convert Joplin tags to inline tags (this can also done automatically).
Have you tried opening a note with Joplin tags and running the command from the menu Note >> Convert current note >> Convert note: joplin tags -> INLINE TAGS. See additional info here.
Brilliant !!
Thanks !!
